Old 06-07-2006, 04:55 PM   #1
even turn off breaker, still show 12 V is this normal
Hi everyone,
I turn off the breaker for a circuit I am working on, the hot wire still show there is 12V, although this is insignificant, just want to know from expert out there, is this normal?
Thank You
KUIPORNG is offline   Reply With Quote
Old 06-07-2006, 05:05 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Are you using a digital multi-meter (DMM)?
It's probably phantom voltage.
Speedy Petey is online now   Reply With Quote
Old 06-07-2006, 05:49 PM   #3
I get a higher reading from 100 foot of wire run underground before I have hooked it to anything on either end.
The DVM is giving you a voltage reading that is not capable of sustaining amps. Phantom voltage, or as we call it A GHOST.
jwhite is offline   Reply With Quote
Old 06-08-2006, 12:12 AM   #4
maybe transients?
Sparky Joe is offline   Reply With Quote
Old 06-08-2006, 03:12 PM   #5
Thanks for the info, For Speedy Petey, I used those lcd displayed little tester for voltage...
Old 06-14-2006, 12:32 AM   #6
did you try turning off all the other breakers as well?
Littlefatdog is offline   Reply With Quote
Old 06-14-2006, 10:04 AM   #7
No I didn't turn off all other breakers,... I just turn off the one I need to work on...
Old 06-18-2006, 03:42 AM   #8
i don't know what are you working on. usually when i test voltage, if there are no voltage the digits changes, but if you have a voltage it should stay, for example you have 12v it should read 11. something to 12. something. if you're sure it is 12v try use a car light bulb or 12v power tester. 12v won't kill you, but it is safe to have it turned off.
justtired is offline   Reply With Quote
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 08:48 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
