European Lamp In America - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2009, 07:45 PM   #1
General Contractor
LakeTahoeDan's Avatar
European lamp in America
I have a client that has a lamp from Europe. 2 round plugs.
The lamp has very special bulbs and thus replacing them is not an option.
What are my choices?
Do I need to get a plug adapter and a converter?
Suggestions please.
& If by some chance I can find the bulbs in 110v what do I have to do, just adapt the plug?
thanks
LakeTahoeDan is offline   Reply With Quote
Old 04-22-2009, 07:57 PM   #2
Civil Engineer
Rewards Points: 4,938
Europe runs on 220 volt single phase, so presumably the lamp is designed for 220 volt bulbs. You can probably find the bulbs on line somewhere, the problem would be finding a 220 volt outlet to plug into. So I assume that is a bad option.
So option 2, if you can find a 110 volt equivalent bulb, you could cut the plug off, and replace it with a 110 volt plug that you can purchase for a few dollars. Hopefully the bulb would put out the proper amount of light, I imagine a specialty lighting store would be helpful in matching the European bulb to an American equivalent.
Old 04-22-2009, 08:00 PM   #3
dSilanskas's Avatar
Suggestions please.
thanks
Or what you could do is you could run a dedicated line to a single 220 volt receptacle. Cut off the cord end that is on the lamp and attach a 220 volt male plug end. That is if they want to keep the funky bulbs with the lamp.
dSilanskas is offline   Reply With Quote
Old 04-22-2009, 08:02 PM   #4
Rewards Points: 156
why not just rewire it?
Why not just pull the wires and rewire the thing?
jayp is offline   Reply With Quote
Old 04-22-2009, 08:15 PM   #5
General Contractor
the lamp is an owl and the eyes are the bulbs.
220 receptacle in an apartment! lol
Can I use some type of converter?
Old 04-22-2009, 08:15 PM   #6
General Contractor
new bulbs are not an option
Old 04-22-2009, 08:17 PM   #7
Yeah, whats the watt rating?
http://www.dvdoverseas.com/store/ind...atalog6_0.html
rgsgww is offline   Reply With Quote
Old 04-22-2009, 08:24 PM   #8
dSilanskas's Avatar
You didn't say it was in an apartment
Old 04-22-2009, 08:28 PM   #9
General Contractor
how many 220 outlets does your house have besides the laundry and range?
It is rare to have a spare 220 in any house or apartment ...imo
Old 04-22-2009, 08:35 PM   #10
dSilanskas's Avatar
Well about about a 220 volt a/c outlet? And If I needed a 220 volt outlet I would install one
Old 04-22-2009, 09:34 PM   #11
Electrical Contractor
jbfan's Avatar
Rewards Points: 648
If the customer is not the owner, then I'm sure the owner would not allow this.
Old 04-22-2009, 10:13 PM   #12
Idiot Emeritus
Rewards Points: 1,492
What wattage are the bulbs?
A transformer that would run a 100 watt bulb would cost around $100. You could wire a 120 volt cord w/plug to it, and wire the lamp cord directly to it. It'd be a box about 6" X 4" X 4", and would weigh about 10 lbs. It'd get quite warm, you'd need to keep it off the carpet.
Sorta ugly, especially around a decorative lamp, but there are not very many other options.
Rob
micromind is offline   Reply With Quote
Old 04-22-2009, 11:06 PM   #13
Might I sugest these units starts at less than $17, switch selectable converts 120 to 220 or 220 to 120, has 2 prong euro outlet and 3 pron U.S. outlet, 2 prong euro cord plug and comes with adapter to 120 U.S. You won't have to change any plugs.
hayewe farm is offline   Reply With Quote
Old 04-22-2009, 11:08 PM   #14
Rewards Points: 150
Maybe it would be cheaper to just shoot the damn owl!
Gary
Gary_602z is offline   Reply With Quote
Converting plug-in pendant lamp to wired from electrical box. Need Help! tioleo Electrical 1 03-15-2009 07:41 PM
halogen desk lamp Banker 21 Lamp bh4bhwgm Electrical 3 09-29-2008 04:55 AM
Fluorescent lamp flickering Ash Electrical 11 08-03-2008 07:35 PM
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 12:16 PM
Using a european lamp in the States mattlima Electrical 3 03-16-2008 08:12 PM
