European 220v Tools Use With US 220v Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-01-2012, 05:11 PM   #16
Rewards Points: 1,418
Generally you can take 50 Hz tools and run them on 60 Hz. (Not vice versa)
Easy to convert. Get a 250 volt rated appliance cord, 2 wire with ground if you wish. Use a cord rated for 20 amps and a "20 amp" 240 volt plug unless you are sure that the tool is rated for more. You can use a lesser rated cord if you are sure the tool is rated for less.
Using a grounded appliance cord and 3 prong plug, connect the green wire to the frame or body of the tool. (A cord with red, white, and black wires only is for 120/240 volt ungrounded use, not 240 volt grounded use.)
Old 08-01-2012, 05:12 PM   #17
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by Amusinglisa View Post
Could either of you elaborate on how to make a two-wire 220 into a three-wire 220?
Why don't you first explain what you mean by this?
What are you calling a two-wire and three-wire "220"?
The Following User Says Thank You to Speedy Petey For This Useful Post:
jbfan (08-01-2012)
Old 08-02-2012, 07:54 PM   #18
If I cut the plug ( two round prongs) off my new 220/240v 50/60Hz 3.1Kw German cooktop, I see two wires - one blue and one beige (or tan). My contractor has explained the neutral and ground or earth concept and that we have to use 4 wires for 220 here inthe US.
Amusinglisa is offline   Reply With Quote
Old 08-02-2012, 08:09 PM   #19
If the 220/240 volt appliance has no 110/120 volt internal components then it needs just a 3 wire cord, two hots for 220/240 volts and a ground. Generally you can keep the existing cord even if there is no ground wire in it but you must use a plug with no ground pin (just two prongs for 220/240 volts only).
Branch circuits in the U.S. must be grounded. This requires 3 wires and ground for equipment using both 120 and 240 volts and 2 wires plus ground for 240 volts only.
Old 08-02-2012, 08:30 PM   #20
It seems euro plugs want 230 all on one wire. Can we do that?
Old 08-03-2012, 12:21 AM   #21
Semi-Pro Electro-Geek
Rewards Points: 2,858
You're fin running a German cooktop on US 240V. Just connect blue and beige to the two hots (black and black, or black and red). You're right that it's somewhat different than the European system, but it will work. The European system expects one wire to be gounded and the other to be 220V. Here, each hot wire is 120V with respect to ground, and 240V between the two hots. The appliance will work fine though. Just be aware that some electronic timers will run 20% fast due to the frequency difference.
mpoulton is online now   Reply With Quote
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 09:08 AM
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 09:18 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
