Equipotential Grid For Hot Tub - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-14-2008, 06:49 PM   #16
Electrician
Originally Posted by jerryh3 View Post
I was hoping you would disagree and prove me wrong.
Sorry, not this time.
chris75 is offline   Reply With Quote
Old 10-14-2008, 08:34 PM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Thats a very good question and the code is rather vague on that issue.
I would have to agree that a grid is required around the perimeter (walking area) but not necessarily under the tub. I suppose for existing concrete you would have to install some sort of insulating surface on the slab such as wood or plastic pad in order to circumvent the bonding grid requirement??
Old 10-14-2008, 08:39 PM   #18
UAW SKILLED TRADES
Stubbie's Avatar
Originally Posted by J. V. View Post
What changes if any, that the tub is above grade sitting on a wood deck specifically built for the tub. A factory contained unit with no metal ladders ect..? Would the EGC, combination disco and recept in site meet the spec? Thanks
JV
If the tub is on a non-conductive surface such as a wood deck then there would be no grid requirement imo.
Old 10-14-2008, 08:59 PM   #19
Originally Posted by Stubbie View Post
JV
That's how I'm interpreting it, and that seems to go along with most inspector's opinions I have found in other forums. I guess I'll just throw down some thick rubber mats and create a nonconductive "walking path" around the tub. I just love helping family. Here's the backstory in case anyone's interested. Had to move a hot tub from a wood deck approx 20' away to pavers on grade. Removed the exisiting spa panel and installed a j-box where that was. Ran conduit from the j-box around the corner to the new location of the spa panel (50A GFCI within the 5' to 50' in sight rule). Extended the circuit with 3 #6's and 1 #10 THWN. Conduit from the Spa Panel to the tub with the 3 sixes and the #10 ground.
jerryh3 is offline   Reply With Quote
Old 10-14-2008, 10:18 PM   #20
Licensed Pro
That would certainly be easier than cutting/digging up an existing patio, but I would not use wood... when wet, it can become conductive, just like the concrete, especially if pressure treated (high ionic content).
Tags
bonding , hot tub
Hi from Off The Grid Tennessee Forest Breath Introductions 3 09-04-2008 03:01 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
