Entire Floor No Power - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2014, 04:30 PM   #1
Question
Entire floor no power
So the other day I was vacuuming in one outlet and had the tv on in the outlet next to it (common practice for myself). This time it blew the breaker. I went and flipped the appropriate breaker to return power normally. A few days later once again I was vacuuming in one outlet, and tv on in the one next to it (same outlets). The power blew again! Only this time it did not blow the breaker. I have an entire floor with no power and several outlets with no power on the upper level.
I have power at the panel throughout all the lines, today I took out every single outlet in my house to ensure proper connections. Every outlet was wired properly. I also checked the wires from the two outlets that "created" the problem, (not positive, as my electrical knowledge is little) with the power on. There is no current running through these wires.
My knowledge is very low on anything electrical. I'm out of ideas.
Need some suggestions/help on how to isolate the problem.
I would like my power back.
It's been several days now
Pitbullprincess is offline   Reply With Quote
Old 04-01-2014, 04:59 PM   #2
I am
there's only so much an internet forum could do
UnclePhil is offline   Reply With Quote
Old 04-01-2014, 05:02 PM   #3
I am
You know anything about electrical wiring...??
turn off the breaker that tripped.. that didn't trip so you don't get hurt..
Open up the receptacle to see if things are tight, loose, burnt...
gotta trace the circuit and see whats going on..
I f a guy knows what he was doing, could get lucky and find it in minutes.. could also take hours..
Old 04-01-2014, 05:51 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,508
first thoughts !
could be several things -
a tripped gfci ? a very common problem !
sometimes they are found in the most unlikely places.
or a bad splice in a hidden j box.
Do you know more about how the house is wired ?
Do you know where the power for the top floor comes from ?
And the route it takes ?
dmxtothemax is offline   Reply With Quote
Old 04-01-2014, 10:37 PM   #5
Rewards Points: 14,020
Did you turn the breaker all the way off before trying to reset?
What are you using to test for power?
Old 04-02-2014, 06:35 AM   #6
The first thing I checked was the breaker panel. All is good. There is current running to and from the panel on that circuit. All GFCI are fine. I've taken apart every receptacle in my house, no wires have been disconnected. Could a light switch cause the problem? Could it be coming from a line with a current?
Old 04-02-2014, 09:27 AM   #7
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
Does the vacuum cause breakers to trip anywhere else?
This one breaker, is the switch firm with a definant click when you turn the power back on with it? Or does it feel loose? Could be a bad breaker.
Gregg M.
gmaint is offline   Reply With Quote
TV power bridge into existing outlet and protected by an external surge protector andytran73 Electrical 4 12-14-2011 08:00 AM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
