ENT (Smurf) feeding a sub in detached garage)
HI;
Are there any restrictions on using flex ent "Smurf" as conduit for a portion of my conduit run to the garage? (The smurf would only be used inside the crawl space and would not exit the house)
The run would look like:
Panel with EMT to Crawl space, EMT in crawl space connects to Flex ENT "smurf" which goes to a J-box inside the crawl space that connects to the rigid Grey ENT that is buried to the garage.
The crawl space is a bit hard to work in. I will run emt if it is necessary, but smurf would save me a lot of time.
It will be a 4 wire feed (2hot, 1 neutral, 1 ground) from the panel to the garage, plus 2 ground rods at the garage.
I just can't figure out if there is any reason not to use smurf because it is feeding a sub panel in a detached building.
Jamie
Jamie Dolan - Neenah, WI
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Need Help Uploading Photos? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
