-   -   ENT (Smurf) feeding a sub in detached garage) (http://www.diychatroom.com/f18/ent-smurf-feeding-sub-detached-garage-37419/)
jamiedolan 02-02-2009 01:26 PM
HI;
Are there any restrictions on using flex ent "Smurf" as conduit for a portion of my conduit run to the garage? (The smurf would only be used inside the crawl space and would not exit the house)
The run would look like:
Panel with EMT to Crawl space, EMT in crawl space connects to Flex ENT "smurf" which goes to a J-box inside the crawl space that connects to the rigid Grey ENT that is buried to the garage.
The crawl space is a bit hard to work in. I will run emt if it is necessary, but smurf would save me a lot of time.
It will be a 4 wire feed (2hot, 1 neutral, 1 ground) from the panel to the garage, plus 2 ground rods at the garage.
I just can't figure out if there is any reason not to use smurf because it is feeding a sub panel in a detached building.
Jamie
J. V. 02-02-2009 01:52 PM
Take the smurf all the way to the first j-box, then PVC to the garage. Just the way I would do it. Or EMT to the first box. Your call. It cannot be subject to physical damage. If you have access to a code book, look at article 362. You need a ground in any plastic conduit.
