Old 04-06-2012, 07:50 PM   #1
Enough Power? Help!
Hello,
I have a 40amp breaker with 8/3 wire running to my garage.
I'm looking to setup a breaker box to use a
Miller 212 mig welder 208/230V phase 1 , 60HZ.
160 Amps at 24.5 VDC, 60% duty cycle
Ingersoll Rand 5-HP 60-Gallon Single-Stage Air Compressor - 230V
some 120 outlets and lights.
I know i probably won't be able to use the welder and the compressor at the same time. I hope i'm providing enough information and how could i set up the new breaker box in the garage?
thanks, Joe
MGKelly is offline   Reply With Quote
Old 04-06-2012, 09:03 PM   #2
Enough Power? Help!
first you need to see on the spec tag and see what the current rating is for the 208/230 volt side.then what the breaker size is required.
oleguy74 is offline   Reply With Quote
Old 04-06-2012, 09:10 PM   #3
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Enough Power? Help!
Both units are about 25 amps so you should be ok with some lights and only using one at a time. If you have a panel in the garage you will need to add the recommended breaker for both and wire a receptacle or direct wire them.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-07-2012, 03:37 AM   #4
Enough Power? Help!
Thanks,
Power strip hack salex Electrical 3 01-31-2012 07:10 AM
Outdoor Hot Tub / Overhead Power line issue scottwilliamson Electrical 3 02-12-2010 11:37 AM
Devices to save on phantom power fetzer85 Electrical 7 12-04-2009 09:03 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 08:45 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
