-   -   Enough Power? Help! (http://www.diychatroom.com/f18/enough-power-help-139469/)
MGKelly 04-06-2012 07:50 PM
Enough Power? Help!
Hello,
I have a 40amp breaker with 8/3 wire running to my garage.
I'm looking to setup a breaker box to use a
Miller 212 mig welder 208/230V phase 1 , 60HZ.
160 Amps at 24.5 VDC, 60% duty cycle
Ingersoll Rand 5-HP 60-Gallon Single-Stage Air Compressor - 230V
some 120 outlets and lights.
I know i probably won't be able to use the welder and the compressor at the same time. I hope i'm providing enough information and how could i set up the new breaker box in the garage?
thanks, Joe
oleguy74 04-06-2012 09:03 PM
first you need to see on the spec tag and see what the current rating is for the 208/230 volt side.then what the breaker size is required.
rrolleston 04-06-2012 09:10 PM
Both units are about 25 amps so you should be ok with some lights and only using one at a time. If you have a panel in the garage you will need to add the recommended breaker for both and wire a receptacle or direct wire them.
MGKelly 04-07-2012 03:37 AM
Thanks,
