Enhancing Existing Wiring To Detached Garage - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 07-07-2008, 07:11 PM   #46
liscenced electrician
Rewards Points: 538
since writing word for word doesn't do any good. ill sum it up to what it says to me
The disconnecting means to a seperate building's feeder or branch circuit(s) shall have a combined disconnecting means rated at not less than the calculated load or a b c or d. Since in this case the calculated load here is practically nothing and it would fall under D (if you were installing a sub panel). It would be saying the disconnecting means for the feeders must be rated at 60 amps
jimmy21 is offline   Reply With Quote
Old 07-07-2008, 07:29 PM   #47
Electrician
Follow along in your code book....
If I run a feeder to a seperate structure, 225.31 tells me I need a disconnect, 225.32 tells me where to install that disconnect, 225.36 tells me it has to be rated as Suitable for Service Equipment, Now for the grand finale, we get to 225.39 RATING of Disconnect, guess what that section tells ya, yep you guessed it, what the rating of the disconnect has to be. and thats IT! hope your a good sport!
I know its easy to read what you want it to say, but you have to read some sections like its your first time reading them and really digest what its actually saying.
chris75 is offline   Reply With Quote
Tags
breaker , electrical , garage
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
Grounding for detached all-metal garage geeswanie Electrical 3 07-03-2008 07:31 AM
detached garage Kapt Electrical 12 01-17-2007 08:37 AM
Framing a carport on a detached garage nomagic Carpentry 3 05-04-2006 10:43 PM
