Enhancing Existing Wiring To Detached Garage - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-04-2008, 01:25 PM   #31
Electrician
Originally Posted by white29 View Post
Jeez, I was going to ask some questions about my own sub panel project, but I'm a little scared to now!
Heres the problem I see with DIY and electricity, can a DIY tackle small electrical jobs? Absolutely... and with a little help they can do it efficiently and to code.
Now the downside, some jobs involve many codes to different applications and to walk someone through them can be a long road, now we throw in the mix of two people that disagree on a code, well that just really screws up the works... and it happens because some people just believe what there told is code or just dont read the NEC anymore. So these things happen.
chris75 is offline   Reply With Quote
Old 07-04-2008, 03:31 PM   #32
Yeah,dont worry,it's all good. I'm just trying a little humor to break the tension. I dont want to hijack the poor original guys thread,I'll start my own tomarrow when I have time. Happy Fourth everyone.
white29 is offline   Reply With Quote
Old 07-04-2008, 08:15 PM   #33
Just a reminder if you decide to go with a subpanel. If you bring a neutral from the house (which you should) remember to remove the ground/neutral bonding jumper that will be already installed in the subpanel. You will need to make sure you have a ground and a neutral along with your hot feeder wires. Remember to seperate them at the sub and do not sink a ground rod at the garage sub. You only bond ground and neutral after the first means of disconnect, which is in your house. You should also only have one grounding location, at the house.
Stavop is offline   Reply With Quote
Old 07-04-2008, 08:56 PM   #34
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
This would be true for a sub-panel in an attached garage/structure.
A detached structure served by a feeder MUST have some form of grounding electrode.
Old 07-06-2008, 03:54 PM   #35
liscenced electrician
Rewards Points: 538
Originally Posted by chris75 View Post
If you dont believe me, then take that statement over to Mike Holts Forum and post that question. I dont know where your reading that the required DISCONNECT must be fed by a certain size wire?
I'm beginning to believe you. Although im still skeptical. Reason being, the way I interpret "the feeder disconnecting means shall have a rating of not less than.... 60 amps" Is that The disconnect would be for the feeder and not further down the line...... Because thats how im taking what your saying. The main for the sub panel, would be 60 amps..............
well i decided to search google. And i found a thread at the mike holt forum, Basicly talking about how stupid the wording is on 225.39.
http://www.selfhelpforums.com/archiv...hp/t-1419.html
I read a couple of other threads. And it looks like your right. You must have a 6 or less disconnects, totaling 60 amps or more to disconnect the garage.
Like i said before though, Its been enforced here that you have run a 60A feeder out there. And its hard for me to believe differently, when its enforced the way that makes sense to me. I'll be bring it up to the inspector here shortly
jimmy21 is offline   Reply With Quote
Old 07-06-2008, 04:11 PM   #36
Electrician
Yes, the feeder disconnecting means, so if you run a 12 AWG feeder, it shall not have a disconnecting rating less than 60 amps, ( the disconnect goes at the seperate structure) no one said the disconnect had to be the over current protection, its just a disconnect. the NEC wants a 60amp Minimum rating, WHY? I dont know.
Old 07-06-2008, 04:34 PM   #37
Electrician
I cant believe it makes sense to you... sorry, but I'm just not reading what your reading.
When you read the Title of 225.39 Rating of Disconnect. how do you come up with the conclusion that a 60 amp feeder must be run?
Old 07-06-2008, 05:18 PM   #38
Rewards Points: 538
no, not that, i mean, after years of an inspector telling me whats what, its hard for me to come on here, and get convinced by somebody i don't know on the internet
Also, i total side note. Id say im a good quality electrician, that does nice clean quality work and gets it done quickly, but i've never claimed that code is my strong point. Maybe its an Oregon addendum, i don't know
Old 07-06-2008, 05:24 PM   #39
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
IMHO, everyone needs to do it as to what works for them. I think it's all dependent upon the AHJ. So let's notName:  beat a dead horse.gif
Size:  7.3 KB <<<<,beat a dead horse
wirenut1110 is offline   Reply With Quote
Old 07-06-2008, 05:26 PM   #40
no, not that, i mean, after years of an inspector telling me whats what, .......
No offense, but you need to know what you are doing before the inspector even gets there.
Neat and quality are necessary to gain a good reputation. Knowing the code is necessary to do the job right so you can sleep at night.
Old 07-06-2008, 05:59 PM   #41
Electrician
Originally Posted by wirenut1110 View Post
IMHO, everyone needs to do it as to what works for them. I think it's all dependent upon the AHJ. So let's notAttachment 4144 <<<<,beat a dead horse
This is more of a learning experience than beating a dead horse...
Old 07-06-2008, 07:08 PM   #42
Rewards Points: 538
are you even an electrician?
[sarcasm] because id never be able to sleep at night if i had just pulled in 60 amp feeders. [/sarcasm] I get what your saying, i agree, code is important and I know you'll give me flack for this, but theres a big difference between something thats "not safe" and ignoring the ticky tack codes when its not getting inspected. Like if the guy ignored 225.39 and just pulled in a 12/3 and put a 20 amp main at the sub panel. I try to do everything up to code, im just saying, you make it sound like an ungrounded pancake box is worse than an open splice on a 12/2 that has an ocpd of 50a
Old 07-06-2008, 09:39 PM   #43
Electrician
I was never trying to make you look bad, I was just trying to teach you what the code actually requires.... Do you really want to run # 6 for every feeder you pull to an outbuilding?
Old 07-06-2008, 10:47 PM   #44
Rewards Points: 538
naw, i appreciate it, i really do, i need to brush up on code. also, Im not trying to argue, just for arguing, you have to admit 225.39 is goofy. Also, i suppose, the "who gives a crap as long as its safe" isn't the best thing to say here, because i've seen plenty of stuff that homeowners thought were safe that i just shake my head at. A good example of what i mean by safe, but not up to code, kinda ironic, (i guess not a violation after all) i ran 50A out to my garage because i had the wire layin around, and its more than what i need. Well i guess its still a violation because it has a 50A breaker on each side. I just kinda gathered from you, that you think if i can't recite article numbers that im out burning houses down
Old 07-06-2008, 11:19 PM   #45
For the sake of discussion, what is it you think 225.39 says?
Read it real close.
Tags
breaker , electrical , garage
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
Grounding for detached all-metal garage geeswanie Electrical 3 07-03-2008 07:31 AM
detached garage Kapt Electrical 12 01-17-2007 08:37 AM
Framing a carport on a detached garage nomagic Carpentry 3 05-04-2006 10:43 PM
