Energy Savings - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 03:29 PM   #1
Energy savings
Will there be a kWh savings by changing from magnet ballasts to electronic ballasts? Existing fixtures use 2 - 40 watt T12 lamps.
Thank you,
Mike
Mike2401 is offline   Reply With Quote
Old 12-05-2010, 03:33 PM   #2
joed's Avatar
Rewards Points: 11,974
There could be if you switch to T8 35 watt tubes.
The Following User Says Thank You to joed For This Useful Post:
Mike2401 (12-05-2010)
Old 12-05-2010, 03:40 PM   #3
Hi Joed,
Thank you for your response.
So, there is not an actual savings if you just change the ballasts to electronic? You would also have to change the lamp wattage?
Old 12-05-2010, 05:09 PM   #4
joed's Avatar
There could be. Some ballasts are more efficient than others. If it was a whole office building probably worth it. If is two lights in your basement I wouldn't bother unless the ballasts are bad and need replacing already.
Setback thermostats & energy savings?? Tinkerer HVAC 7 01-29-2010 07:13 AM
Fuel savings from burner/nozzle reduction EfficientCanuck HVAC 13 03-01-2009 08:21 PM
Energy Star Appliances Re: Washer-Dryers jaesun Appliances 5 05-28-2008 10:34 AM
