Energy Saver On Water Heater? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 04:41 PM   #1
Question
Energy Saver on Water Heater?
I just moved into a condo and noticed that there is an Energy Saver tag on my A/C unit and my water heater. I also noticed that the water pressure is extremely low when I want to use hot water..cold water comes out normally.
What do I do??? Am I even able to do anything or do I have to get my local power company to handle?
MisezDiana is offline   Reply With Quote
Old 09-29-2010, 04:45 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
The energy saver has nothing to do with the water pressure.
The energy saver allows the POCO to kill the power to these devices during peak demand days.
Are you buying or renting?
Old 09-29-2010, 05:00 PM   #3
i'm buying.
So does that mean I need a new water heater?
Old 09-29-2010, 05:02 PM   #4
What floor is the condo on ?
Old 09-29-2010, 05:04 PM   #5
its on the 1st
Old 09-29-2010, 05:55 PM   #6
Licensed electrician
Rewards Points: 1,634
Does this affect every faucet in the house or just some? Have you cleaned the screens on the faucets? How does your pressure compare to your neighbors?
Old 09-29-2010, 06:30 PM   #7
Every shower, faucet and even the washer.
I've never thought to ask my neighbors. I was convinced that it had something to do with the energy saver thing.
Old 09-29-2010, 10:34 PM   #8
I=E/R
a7ecorsair's Avatar
Water pressure between the hot and cold faucets would be within your unit. If there are any shut off valves by the water heater make sure they are fully open. Can you see enough of the piping to tell if it is iron pipe, copper pipe, or something else?
a7ecorsair is offline   Reply With Quote
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Replaced water heater, still smelling sulfur in hot water & Low water pressure aminus21 Plumbing 2 07-21-2010 04:40 PM
settings for indirect water heater doug32 Plumbing 0 07-14-2010 06:04 PM
Tankless Water Heater welshie Plumbing 12 03-03-2010 12:46 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
