Old 08-26-2011, 05:28 PM   #1
BPC
Energy Saver PAR30 Lamps
I currently have Halo H5RICAT housings with the 5001P white baffle trims throughout my house. With this trim ring and housing, I'm limited to a 50W PAR30 lamp, but I want to use something with more lumens like a 75W PAR30.
Recently I've seen these new GE energy saver halogen bulbs in the store that have similar light output as the 75W PAR30, but are only rated at 48W.
My question is, can I use these in the housing since they are 50W, or will they be a fire hazard, since they weren't tested by the manufacturer.
I would assume, they would get just as hot as the 75W PAR30, but maybe I'm mistaken.
Comments,
Thanks,
Brian
BPC is offline   Reply With Quote
Old 08-27-2011, 01:56 AM   #2
JOATMON
ddawg16's Avatar
Have you considered a CFL in a PAR configuration....get the output of 100w light bulb and only uses about 23w. Otherwise, I'm not sure I would want to push it on the wattage limit....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 08-27-2011, 07:48 AM   #3
Electrical Contractor
kbsparky's Avatar
You can use a 48 watt bulb in a fixture rated for a max. of 50.
The fixture is only interested in the amount of current draw, not the light output.
-KB
Whirlpool Energy Saver Water Heater Problem Thurman Electrical 33 03-12-2013 10:05 PM
Energy Saver on Water Heater? MisezDiana Electrical 7 09-29-2010 11:34 PM
energy saver on water heater jhowd Electrical 11 09-07-2010 12:08 PM
HVAC energy saver Sappronie HVAC 4 09-06-2007 12:34 PM
