Old 04-05-2008, 01:36 PM   #1
banging thumbs
Enclosure for old exterior Electrical Box
When the old home owner moved the electric panel, they left the old box as an enclosure for the wiring. It's big and an eyesore. I would like to remove it and install a smaller enclosure box to house the wiring.
I found the enclosure box below at HDepot, and turning the power off and marking the wires before disconnecting is straight forward. My question is regarding the ground bar on the right hand side of the photo. What is the proper way to deal with this in regards to the new enclosure? Can it be removed and reconnected to the new enclosure?? I want to make sure I do everything correctly.
Thanks.
Enclosure for old exterior Electrical Box-oldbox.jpg   Enclosure for old exterior Electrical Box-ground.jpg   Enclosure for old exterior Electrical Box-enclosure.jpg
bakerhouse is offline   Reply With Quote
Old 04-05-2008, 01:47 PM   #2
My License Ain't 4 Sale..
There seems to be only one ground in the box. So, verifying that you have a good ground, you should be fine in just attaching the wire to a screw in a tapped hole in your new box. It likely already has a hole tapped for a 10-32 screw. It wouldn't hurt to use bond bushings on the other conduits and jump them all to this screw as well.
Edit: Holy Cripes! I didn't see the green wire tied with the reds! You need to figure out just exactly you have going on there first. Or have an electrician do it.
InPhase277
Old 04-05-2008, 01:53 PM   #3
banging thumbs
Great. I appreciate the fast feedback.
Old 04-05-2008, 02:20 PM   #4
When is fishing season?
CowboyAndy's Avatar
Why is there a green wire spliced with a group of reds? If that is a hot wire, then you should mark it somehow to note that it is hot. USe something like a sharpie and color ot black or red, or use black or red tape.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 04-05-2008, 02:21 PM   #5
Doesn't seem to me your alternative is much of an improvement...
LawnGuyLandSparky is offline   Reply With Quote
Old 04-05-2008, 04:18 PM   #6
banging thumbs
Beauty is in the eye of the beholder IMO, a 6x6 box is much less of an eyesore than a old full length dead breaker box. If it was as simple as boarding it over I would.
I'm a novice, but understand. I'll mark it accordingly.
After pulling the covers off, I see there is a large white wire connecting to the bar with the ground. I believe it's called a neutral bus bar.? Can you advise how to deal with this? Thanks.
Old 04-05-2008, 07:33 PM   #7
Electrical Contractor
You have a couple of issues that only someone onsite will be able to evaluate.
After seeing the second pic. I would recommend an electrician.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 04-07-2008, 10:28 PM   #8
banging thumbs
My electrician friend came by today and confirmed it was okay to proceed with the exposure box. A quick pull on the feed coming for the top confirmed it was cut/disconnected and the previous electrician just chose to leave it connected at the box.
Thanks to all for the feedback.
Bathroom Shower Enclosure charliefixit Building & Construction 1 04-08-2008 03:34 AM
DIY replacement of neo angle shower enclosure feasible? hfoster Remodeling 4 02-14-2008 10:38 PM
Steam Heat - Radiator Enclosure Leah Frances HVAC 1 01-27-2008 02:49 PM
any instructions on how to install aluminum porch enclosure? brisk Building & Construction 2 12-14-2007 07:01 PM
Need help picking an outdoor enclosure coyote556 Electrical 13 08-06-2007 05:24 PM
