Emt Raintight Fittings - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 07:16 PM   #1
Rewards Points: 320
emt raintight fittings
It's been awhile since I've done any outside conduit work. I was at the Depot and also Lowes today. They both had two different compression connectors. One was listed as concrete tight which looks like the old connectors that I have used in the past. The other one was a shiny steel type that is fatter at the nut. I looked on the Arlington Industries web site and they list some of theirs as rain and concrete tight. Are all compression type connectors suitable for outdoor/rain conditions?
teamo is offline   Reply With Quote
Old 09-26-2010, 07:19 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Unforetally no not all are listed for outdoor useage you have to check the package to see what they are listed for.
Not too long ago they change the design a little on compression fitting to make sure it will meet the NEC or CEC codes so check the package to make sure.
Merci.
Marc
New House + PEX + Plastic Fittings = ? GaryZ Plumbing 22 01-06-2011 08:47 AM
Problem joining copper fittings after fluxing. mikeg12 Plumbing 7 09-23-2010 12:29 PM
remove compound from brass fittings to unscrew fittings purpleheart Plumbing 3 05-08-2010 06:49 AM
Sharkbite brand PEX fittings at Home Depot rjniles Plumbing 1 03-16-2010 07:33 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 08:16 PM
