EMT Pipe Cutting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 08:11 PM   #1
EMT pipe cutting
Can someone tell me how to cut EMT pipe? I need a very clean, straight, cut. Thanks.
JaneAshley is offline   Reply With Quote
Old 02-27-2010, 08:14 PM   #2
joed's Avatar
Rewards Points: 12,024
Hacksaw. Pipe cutter. Sawsall. Metal chop saw. Metal cutting blade in angle grinder.
Ream the hole when done.
Old 02-27-2010, 08:14 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
is this for something other than an electrical installation?
for electrical use, I just use a fairly fine toothed hacksaw. You still have to deburr the cut.
If you need something more accurate, you could use a tubing cutter but that does make an inward curl that you would have to remove lest it might chafe or cut the insulation on the wire.
Old 02-27-2010, 08:25 PM   #4
Thanks for the info.. I'm using it as part of a quilt frame and the ends must fit in end caps that came with the kit. Fabric will be rolled onto it, FYI.
Old 02-27-2010, 08:26 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Hack saw with a 32 tooth blade.
Since this is for a non-electrical application a pipe cutter will work good too.
Old 02-27-2010, 08:48 PM   #6
nap
You talking to me?
nap's Avatar
just do NOT stick your finger in the end of the pipe and spin it around to see if it is sharp.
it is sharp.
trust me...
I know.
Old 02-27-2010, 08:57 PM   #7
That's good info, nap. It's almost like you know me.......
Old 02-27-2010, 09:16 PM   #8
nap
You talking to me?
nap's Avatar
I know me
Old 02-27-2010, 10:22 PM   #9
Been There Done That ??????????
kerry42 is offline   Reply With Quote
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
(pic) cutting 3" pvc pipe with helpmefolks Plumbing 13 03-31-2009 06:10 PM
Cutting concrete to hide an a/c drain pipe? CooperChloe Building & Construction 3 02-04-2009 09:28 PM
Cutting Iron Drain Pipe jonathan03 Plumbing 12 01-31-2009 10:33 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
