EMT Ends: Bushing Needed? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2008, 05:31 PM   #1
DIYer
EMT Ends: Bushing needed?
Hi all,
My boss helped me install some outlets on a new circuit in my basement a few years back. He's a traditionalist and got me to use EMT instead of the blue plastic stuff. These are exposed outlets mounted on bare concrete walls.
My concern is at the top of the EMT where the romex exits the EMT to continue the circuit in the floor joists. Should this raw romex/EMT edge have an insulated bushing? If so, is it code required or just a good idea? I didn't see EMT insulating bushings at my home improvement store when I looked quickly.
I can take pictures if none of this makes sense.
Gigs is offline   Reply With Quote
Old 10-26-2008, 06:05 PM   #2
Rewards Points: 2,350
Originally Posted by Gigs View Post
Hi all,
Ideally, when changing over from romex to EMT, the pipe would terminate into a junction box, or at least a connector, which you would screw a coupler on, then screw in a romex clamp. Then, the romex would be stripped the length that it runs in the pipe.
Old 10-26-2008, 06:07 PM   #3
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
But this would put the box inside the basement ceiling if the ceiling is finished.
Can't bury the junction box...
Jamie
jamiedolan is offline   Reply With Quote
Old 10-26-2008, 06:25 PM   #4
Put an (edit) insulated throat connector on the end.
Aren't they all insulated throats these days??
220/221 is offline   Reply With Quote
Old 10-26-2008, 06:46 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Gigs, your question of whether it's code required to have a bushing is yes.
InPhase's idea is nice, but most of time I use a EMT connector with a plastic bushing screwed on, and secure the cable within 12". Less work and material. Stripping of the sheath is no longer permissible. The sheath has to be complete in the conduit and extend into the box at least 1/4". {334.15 (C) Unfinished Basements and Crawl Spaces}.
Jamie...can't bury the box behind drywall, but you can have the box above a drop ceiling.
Kyle
Old 10-26-2008, 07:26 PM   #6
Licensed electrician
Rewards Points: 1,628
These are suitable for use with NM also.
http://aifittings.com/b_1.htm
Old 10-26-2008, 07:32 PM   #7
I believe the OP said they couldn't be located at the local home supply. I personally don't like the idea of running romex into the pipe in this manner, unless the pipe is only a sleeve between floors. But terminating into a device box... I wouldn't do it.
Old 10-26-2008, 08:00 PM   #8
You could also use a combination coupling which is specifically designed to transition from EMT to Romex. I wouldn't bet my last dollar that the big box stores carry these, however.
Matsukaze is offline   Reply With Quote
Old 10-26-2008, 08:12 PM   #9
I just picked up some of these for some romex running down a concrete wall, they work great.
rgsgww is offline   Reply With Quote
Old 10-26-2008, 10:07 PM   #10
DIYer
Thanks for the information guys.
Old 10-27-2008, 10:29 AM   #11
Rewards Points: 160
Yep, both of them carry this item.
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 08:15 AM
understanding prewire in remodel help needed cmcgraw Electrical 13 09-20-2008 04:19 AM
Help...advice needed citadel Roofing/Siding 3 08-01-2008 11:38 PM
Trimming hardwood floor ends... kemerick Flooring 1 12-27-2007 03:48 PM
