EMT Connections - Problems Pulling - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-22-2008, 02:52 AM   #16
Rewards Points: 378
Originally Posted by Matsukaze View Post
Greenlee makes one for EMT that supposedly doesn't leave a burr like a plumbing cutter does. http://www.greenlee.com/archive/8600...Cutter_rel.pdf
I bought that Greenlee cutter, I did not like it. It did not cut deep enough into the conduit. I replaced with Ridgid tubing cutter. Every cut I have seen with a saw left a real jagged edge. Cutting part way through and then snapping is what I have done for several years.
fireguy is offline   Reply With Quote
Old 11-22-2008, 05:38 AM   #17
Rewards Points: 1,192
They should discontinue 1/2 " conduit.
bobelectric is offline   Reply With Quote
Old 11-22-2008, 11:03 AM   #18
Rewards Points: 506
Send a message via AIM to theatretch85
Why? When your running conduit from outlet to outlet you only need 3 12 gauge wires, 1/2" is more than enough for that! There are many applications where 1/2" is all that is needed and going to 3/4" would be just way to excessive.
theatretch85 is offline   Reply With Quote
Old 11-22-2008, 11:32 AM   #19
Rewards Points: 160
What? While I run 3/4" most of the time in commercial, 1/2" almost entirely in residential.
Are you saying they should do away with 14/2 also?
You can get quite a few conductors in 1/2"
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
phone problems AStott Electrical 13 06-07-2008 06:27 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
