Emergency Kill Switch For Workbench? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2013, 04:48 PM   #1
Emergency kill switch for workbench?
Hello folks,
I'm adding an electrical outlets next to my workbench in the garage. I'll be running my drill press, sanders, and band saw for the crafts we like to do. Now I'd like to add a push button kill switch in front of my 4 outlet plug. Just in the case anyone has any kind of problem while working with the equipment and needs it turned off in a hurry.
Does anyone have any suggestions about where to locate a quality mushroom button (red?) kill switch that I would simply add to my circuit?
Thanks in advance!
doorguy500 is offline   Reply With Quote
Old 09-01-2013, 05:20 PM   #2
Civil Engineer
Rewards Points: 4,854
Any decent electrical supply house should have them, just tell them the required voltage (presumably 120V) and amperage. I use an ordinary contractor grade switch next to my table mounted router, but maybe a push button would be safer.
Old 09-01-2013, 05:31 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Most push button contact blocks I've dealt with are rated for about 10 amps.
Not to say they don't make them rated higher.
I would suggest a using a contactor or shunt trip and have your maintained mushroom switch operate those.
Make sure it's a "maintained" switch and not a "momentary".
Just google emergency stop or mushroom push button or http://automationdirect.com
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
mpoulton (09-02-2013)
Old 09-01-2013, 06:18 PM   #4
I was looking here http://energycontrol.com/Emergency_S...e_Station.aspx
and was about to order it, but then the question came up about being normally open or normally closed? And is this a decent price for the item I'm looking for?
What does it mean to be "maintained" vs "momentary"?
Old 09-01-2013, 06:26 PM   #5
Rewards Points: 510
A momentary switch will spring back after you release it. A maintained will maintain the position until you either pull it back out or twist to release.
You want maintained.
Edit:And you want normally closed.
Old 09-01-2013, 06:44 PM   #6
Rewards Points: 510
Once again, you need to check the contact ratings.
You can't just install a 10 amp switch on a 15 or 20 amp circuit especially with motor operated equipment.
Old 09-01-2013, 07:02 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
Those mushroom switches are used for motor controls and the like. They ARE NOT meant to be a disconnect or emergency switch by themselves.
Just get a regular 20A wall switch.
Old 09-01-2013, 07:04 PM   #8
Huh. I stand corrected. I see they do have 20A continuous duty contact blocks for them.
I will say, their prices seem a bit outrageous!
Old 09-01-2013, 07:09 PM   #9
Rewards Points: 510
Yeah it is!! I think I'd go another route.
Old 09-01-2013, 07:12 PM   #10
Like a wall switch. lol
Looking around, I think the 20A rated contacts might be only 24V. I don't see any switches like this for 120V/20A.
Old 09-01-2013, 09:10 PM   #11
" Euro " electrician
frenchelectrican's Avatar
There is a better idea why not get a single pole contractor and have one or two mushroom E-stop switch wired in series that may work but I do not know how big the workbench have in your place.
Merci,
Marie et Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 09-02-2013, 02:51 PM   #12
Rewards Points: 510
Gee, that was a better idea, wished I'd thunked it.
Old 09-02-2013, 02:53 PM   #13
Personally I think this whole project is being way overthunk.
Old 09-02-2013, 03:08 PM   #14
Rewards Points: 510
No doubt, just stick a receptacle tester in there that has the GFI tester in it, when there's an issue just press the little black button and the circuit will trip....lmao
Old 09-02-2013, 03:10 PM   #15
Rewards Points: 170
Just curious if something like this would work or if it is strictly for motors (guess I am asking for both you and I) http://www.amazon.com/Woodstock-D415...mp+kill+switch
or this
http://www.amazon.com/Woodstock-D415...ef=pd_sim_hi_1
diyer111 is offline   Reply With Quote
3 way switch layout has me confused crescere Electrical 5 09-08-2012 10:26 AM
confused on switch replacement fullpint Electrical 6 07-11-2011 08:39 AM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 12:54 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Furnace Emergency Switch Placment arichard21 Electrical 2 01-21-2008 11:32 AM
