Old 02-24-2011, 02:59 PM   #1
eliminating an outlet
I have an outlet that I need to eliminate. It's at the end of a run.
Is it safe(and legal) to disconnect, wirenut/tape and leave the box
and wires in the wall. THEN.... cover it with a cabinet (ie. it will not be accessible, but it's also not a junction box)?
Thx in advance
tmorriss is offline   Reply With Quote
Old 02-24-2011, 03:16 PM   #2
A "Handy Husband"
rjniles's Avatar
Find the other end of the wire and disconnect and wire nut. Remove receptacle, wire nut ends and install blank cover. A nice touch is to leave a note saying wire is abandoned and where the other end is located.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 02-24-2011, 04:54 PM   #3
DIY'er
jamiedolan's Avatar
Thx in advance
No. You can not just cap it off and cover it. You need to find what box it connects to and disconnect it there. All boxes with live connections in them must remain accessible.
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
Old 02-24-2011, 04:55 PM   #4
Learning by Doing
Leah Frances's Avatar
The wires must be terminated in a jBox. The jBox MUST be accessible. Nut, tape and wire as recommended.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-24-2011, 07:57 PM   #5
Electrical Contractor
I would not even worry about the other end.
Wire nut the wires, put a blank cover on the box and cover with the cabinet.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Switched Outlet Issue mjm Electrical 11 01-23-2011 08:41 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
