-   -   eliminating an outlet (http://www.diychatroom.com/f18/eliminating-outlet-96446/)
tmorriss 02-24-2011 01:59 PM
I have an outlet that I need to eliminate. It's at the end of a run.
Is it safe(and legal) to disconnect, wirenut/tape and leave the box
and wires in the wall. THEN.... cover it with a cabinet (ie. it will not be accessible, but it's also not a junction box)?
Thx in advance
rjniles 02-24-2011 02:16 PM
Find the other end of the wire and disconnect and wire nut. Remove receptacle, wire nut ends and install blank cover. A nice touch is to leave a note saying wire is abandoned and where the other end is located.
jamiedolan 02-24-2011 03:54 PM
Thx in advance
No. You can not just cap it off and cover it. You need to find what box it connects to and disconnect it there. All boxes with live connections in them must remain accessible.
Leah Frances 02-24-2011 03:55 PM
The wires must be terminated in a jBox. The jBox MUST be accessible. Nut, tape and wire as recommended.
jbfan 02-24-2011 06:57 PM
I would not even worry about the other end.
Wire nut the wires, put a blank cover on the box and cover with the cabinet.
