Old 09-21-2012, 10:09 AM   #1
Doing it myself
Alan's Avatar
Elevation question : Wall oven junction box
Would I be correct to assume that I should put the j-box in the upper cabinet of the wall oven?
Otherwise I see no way to access the wiring if it's behind the oven.
Journeyman Plumber
Old 09-21-2012, 10:12 AM   #2
Licensed electrician
The installation instructions normally show the JB locations. I have always mounted it behind the oven at the top.
Code05 (09-21-2012)
Old 09-22-2012, 04:43 PM   #3
Doing it myself
Alan's Avatar
Thanks. I thought I had looked, but I double checked again, and it doesn't have a R.I. location for the JB.
To clarify, you're mounting it in the cabinet above the oven so that the connection can be made after the oven is slid into place?
Journeyman Plumber
Old 09-22-2012, 10:47 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Most case it useally either at the top or bottom depending on which type of oven it used.
But if you have plenty room near the top of the oven then go that route otherwise go to the lower cabent for connections.
Merci,
Marc
Old 09-23-2012, 12:23 PM   #5
Doing it myself
Alan's Avatar
Merci,
Marc
Top cabinet = less 8-3 wire, so I will go that route. Thanks Marc, as always.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
frenchelectrican (09-23-2012)
Old 09-23-2012, 09:04 PM   #6
You can normally set the oven in the opening on the shelf and reach above the unit to wire it. If the JB is in the cabinet above you lose some cabinet space.
Old 09-23-2012, 11:20 PM   #7
8-3 NM ? are you using the double oven format ? if that so that is correct but for single oven typically 10-3 useally take care of it unless you got the model number and the specs then go from there.
Merci,
Marc
Old 09-24-2012, 01:02 AM   #8
Doing it myself
Alan's Avatar
Merci,
Marc
Yep, it is an oven/micro combo, requires 40A to operate.
Journeyman Plumber
frenchelectrican (09-25-2012)
Old 09-24-2012, 10:30 AM   #9
4 ' to top.Then 10-2 to cooktop.
bobelectric is offline   Reply With Quote
Wall oven too Wide for Cabinet victor07 Carpentry 8 01-03-2011 12:09 AM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
Oven - junction box in cabinet DIYGST Electrical 5 11-13-2008 04:23 PM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 01:14 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
