Electronics Please..got A Problem About Wirng - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2011, 07:11 AM   #1
electronics please..got a problem about wirng
what are the values of the direct burial of these wire gauges? 2.0mm, 3.5mm, 5.5mm,8.0mm,14mm,22mm,30mm,38,mm
i need help help please anyone who knows about wire ampere rating..thanks
willmae is offline   Reply With Quote
Old 04-24-2011, 07:14 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
It would help if you told us where you are. Obviously not the US or Canada, I assume the UK?
Also, in the US there are different amperages for different applications. There is no blanket one-size-fits-all chart. Your area may be similar.
Speedy Petey is online now   Reply With Quote
Old 04-24-2011, 08:13 AM   #3
joed's Avatar
Rewards Points: 13,766
Your local code book should have the values you need.
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Getting small shock from household electronics cases (in Asia). Why? scootley Electrical 16 11-11-2009 10:09 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
