Electronic Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 08:09 PM   #1
Electronic Timer
I have a Paragon EL71/120 timer that I would like to install to shut my pool timer on and off. There are eight terminals on it. If my logic is correct, the timer needs to be in line between the breaker and pump. I am installing in the basement to keep it from the elements.
Should I wire the breaker to the timer and the timer to pool? If so, where and what wires go on each terminal?
kybuckeyes is offline   Reply With Quote
Old 07-07-2013, 08:26 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Power in on 4(hot) and 5(neutral)
Jumper between 4 & 1 and/or 4 & 6.
Pump out on 2 & 5 or 7 & 5.
This is if everything is 120 volts AND the pump is 1 HP or less.
wirenut1110 is offline   Reply With Quote
Electronic Timer Switch Hookup pmpj218 Electrical 6 04-18-2012 11:43 AM
Anyone have an electronic water heater timer? Homerepairguy Plumbing 11 04-10-2012 05:07 PM
Programmable electronic timer switch to electronic door lock? freedom1st1776 Electrical 19 03-10-2012 09:39 AM
looking for an electronic ball valve with timer tominator Plumbing 1 03-24-2011 12:05 AM
Install an electronic timer CaJazzman Electrical 8 08-13-2008 04:12 PM
