Electrolosis? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 12:13 AM   #1
electrolosis?
One of the copper pipes in my house sprung a leak and I called the plumber to fix it and he said that it had electrolosis on it which is cause by electricity going through the pipe and it must be a ground wire. The house has old knob and tube wiring so there is no ground that I know of. The panel isn't grounded to the water line only to the earth. My question is what could it be that's grounded or how could it be grounded to the pipe. Why would it be grounded from somewhere else besides the panel. Thank you
If you have any questions because I wasn't clear please ask
jmans8666 is offline   Reply With Quote
Old 08-25-2011, 12:40 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,852
The electrolysis problem is not likely to be caused by utility power. It's caused by connections between iron and copper pipes without galvanic isolation. Since you said the house is quite old, it's likely that you have some iron pipe in there somewhere. Probably quite a bit of it. The details of how to solve these problems are a bit outside my normal plumbing knowledge, but a good plumber who works on old houses regularly can help.
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Code05 (08-25-2011)
Old 08-25-2011, 12:41 AM   #3
Code05's Avatar
Rewards Points: 1,104
Bull pucky. Plumber is full of it.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
NJMarine (08-25-2011)
Old 08-25-2011, 01:57 PM   #4
Well my father did say he got rid of the iron pipes as much as he could with out ripping out the walls so there is only iron pipes up stairs. So what is needed to fix this.
Old 08-25-2011, 02:14 PM   #5
Code05's Avatar
I do not know about plumbing problems, but is the main water supply to the house copper or iron by chance?
Old 08-25-2011, 03:55 PM   #6
The main supply is all copper the plumbing was redone to as new as possible without taking down walls. So anything that is behind a wall is iron. The whole basement is copper pipe
Old 08-25-2011, 09:04 PM   #7
Code05's Avatar
If you do not have a bond/ground wire between the panel and water supply pipe, you need a wire within 5 feet of where it enters the house. If you have a water filter or any plastic or such, then you have to install jumper wires around.
Some areas require that a jumper wire wire be installed at the water heater between the hot and cold pipes.
What size is your panel main breaker/service?
Old 08-25-2011, 11:41 PM   #8
So all I need to do is ground the water line from the panel and it will fix this? It's a 200 I think ill check when I get the chance
Old 08-26-2011, 09:07 AM   #9
Code05's Avatar
The ground wire to the water line will fix your electrical violation, it will not help with your leaking pipes.
You need a #4 copper wire attached to the pipe within 5 feet of where it enters the house. You will need a jumper across a plastic whole house filter if you have one
Some areas also require a jumper between the hot and cold at the water heater.
Old 08-26-2011, 01:19 PM   #10
Okay well I figured it should have been grounded to the water line but does anyone know what will fix the pipes
Old 08-26-2011, 01:24 PM   #11
Code05's Avatar
This is the electrical section. Post your question in the plumbing.
Old 08-26-2011, 02:46 PM   #12
I post it in electrical because of what the plumber told me
Old 08-26-2011, 03:09 PM   #13
Licensed electrician
Rewards Points: 996
What does this post have to do about hair removal?
Old 08-26-2011, 09:39 PM   #14
Lol funny just the plumber told me I had a bad ground or something and it was causing leaks
