Electrified Pool - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 10:34 AM   #16
I don't know if anyone makes a Stay Out of the Pool alarm, but here are the basics, at least in principle. If I had a pool I probably would have done this.
-Put 3 stainless steel spikes in the ground in an equilateral triangle pattern with the pool in the middle and measure the voltage between each spike.
-Measure your pool voltages.
-Divide the max spike voltage, e.g., 3v, by the max pool voltage, e.g., 1.5v, to get the ratio (in this case, 2).
Mike Holt says over two pool volts is a problem so in this case a spike voltage of over 4v may mean "stay out of the pool".
For $20 in parts an audible alarm could be hooked up to monitor these voltages. It'd be several comparators with their outputs in a wired-or configuration.
If your pool is not yet built you could run insulated wires in the pool concrete to monitor critical points directly without using ground spikes.
You are looking for voltage differences between places that people may touch.
Old 07-05-2012, 05:01 PM   #17
Rewards Points: 1,300
A properly designed and installed bonding sytem will put all of these voltage gradients into the same potential and eliminate the shock potential.
danpik is offline   Reply With Quote
Old 07-05-2012, 05:47 PM   #18
In principle, yes.
I wonder how many old and new pools show over 2v during a power-line-down condition, for whatever reason. This is not easily tested.
Old 07-05-2012, 07:09 PM   #19
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
In principle, yes.
None if they have a EBG, as for older pools, impossible to calculate real statistics.
Is being shocked in a properly bonded pool truly impossible or just improbable? LeighB Electrical 36 05-30-2013 12:08 AM
Electrical run to new pool house AlwayzSomethin Electrical 11 04-26-2012 01:47 PM
In-Floor Swimming Pool Cleaning System Silkcityflorida Plumbing 0 03-22-2012 11:21 AM
Bonding Pool Equipment - Conflicting Advice rickster18 Electrical 6 08-18-2011 05:21 PM
pool deck, carpenter help rollinastang Building & Construction 9 07-01-2011 06:21 AM
