Electrified Metal Door - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 01:17 AM   #1
Rewards Points: 87
So imagine my surprise today....
Remodeling my master bathroom, I ran a new cold water supply line. When I hooked up the faucet, it didn't work. This is a double wide mobile home with water heater access on the outside. It had just started a light raining so I figured to run outside to check it out.
So I touched the door and got zapped. Not a bad zap, bout how it feels if you forgot to test an outlet before working on it. Just enough to get your attention.
I've done lots of work over in that area lately, and never got shocked before. So I figured the water helped me ground out. I was testing the idiot way. Flipping sets of breakers and testing if I still getting zapped. As I've got a ton of breakers between three panels, I narrowed it down to about 8 breakers (it's not the water heater circuit) before I got tired of getting zapped.
Since it has stopped raining,and will likely be mostly dry tomorrow morning, how do I test this out with a multimeter to see if the door is still hot?
Thanks,
Timothy
myowneq is offline   Reply With Quote
Old 02-03-2012, 01:27 AM   #2
Rewards Points: 6,652
So you got shocked by static electricity. It happens.
Old 02-03-2012, 01:30 AM   #3
Rewards Points: 264
If you don't think it was static electricity, go and get a small multi-meter. You can get a cheapy (but still UL listed) for $15 bucks.
a_lost_shadow is offline   Reply With Quote
Old 02-03-2012, 01:33 AM   #4
Rewards Points: 87
I would find it hard to believe it's static electricity. With all breakers off, I get no shock. Thinking back, it might have been the better idea to flip the breakers on one by one rather than off in sets.
From experience, I know only the frame, door, and screws to hold it in place are metal. Everything else around it is wood and vinyl siding.
I figured the multimeter part, but where do I stick the neutral lead?
Thanks,
Timothy
Old 02-03-2012, 04:35 AM   #5
Rewards Points: 3,256
Thanks,
Timothy
Stick one of your leads into the ground where you were standing. It may be that one of the screws holding the frame on has pierced a wire. If this metal door is purposely bonded to ground then you may have other issues.
zappa is offline   Reply With Quote
Old 02-03-2012, 06:38 AM   #6
Rewards Points: 1,494
Measure voltage between the door frame and a variety of other places notably the screw holding the cover on a switch or receptacle, a water pipe, and the neutral prong hole (the larger of the two slots) of a receptacle, the metal frame or box for the electric meter, and a ground rod if there is one.
Old 02-03-2012, 09:12 AM   #7
Assuming the max voltage you'll see during testing is 120v it will be more informative to simulate your skin/body resistance by putting a 15K, 1W or 2W resistor across the voltmeter leads.
Assuming you got a >5 mA shock you'll be seeing >75 v across this resistor. Radio Shack can supply this part.
Be careful.
Old 02-03-2012, 10:37 AM   #8
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Why three panels?
rrolleston is offline   Reply With Quote
Old 02-03-2012, 10:56 AM   #9
Rewards Points: 87
First panel was installed outside under the meter. I have no clue why they installed that one outside. It provides power to main house panel, addition sub panel, and camper (installed by me).
interesting patio door problems....please help. diybrad Building & Construction 6 11-20-2011 11:52 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Repair of Door with Metal Interference Weatherstrip KAdams4458 Carpentry 4 09-18-2009 08:38 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
