Which Electrick Cable For Shower? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2008, 10:20 AM   #1
Which electrick cable for shower?
Hi every one, i just joined the Forum, i hope some one can help me, i have a shower that i bought a couple of years ago, and i have only just got round to installing it.
The Shower is a Galaxy Serene 9.5 KW, and i would like to know what amperage cable is required for this particular model?
I lost the booklet that came with it, and the the Galaxy web site does not have a booklet for this model anymore.
Any advice would be more than welcome.
Andy_Andy is offline   Reply With Quote
Old 09-22-2008, 10:41 AM   #2
Electrical Contractor
Need the voltage rating on the unit.
hpp58 is offline   Reply With Quote
Old 09-22-2008, 02:35 PM   #3
Are you in the US?
jerryh3 is offline   Reply With Quote
Old 09-23-2008, 07:59 AM   #4
Its 240 volts and ime in the UK.
Thanks.
Old 09-23-2008, 10:04 AM   #5
Whatamess
It would be 40 Amps and #6 wire
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 09-23-2008, 10:39 AM   #6
Thanks TazinCR 6 Wire? - is that 6mm?
Old 09-23-2008, 11:04 AM   #7
Im in the us but I found this chart that might help.
http://www.unc.edu/~rowlett/units/scales/wiregauge.html
rgsgww is offline   Reply With Quote
Old 09-24-2008, 06:49 AM   #8
6 Wire?
6# is commonly referred to "6 gauge" or "6 awg" here in the us.
We use the "American wire gauge" much different than using the metric system, and is supposed to make it easier for wiring.
There is some conversion charts out there, but im no good in uk wiring, so check with your codes.
Old 09-24-2008, 08:27 PM   #9
" Euro " electrician
frenchelectrican's Avatar
The wire size in UK you will need 16mm2 twin core and I am pretty sure you will need the shower head power circuit to be RCD'ed.
Merci,Marc
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 08:00 AM
Projector Receiver cable TV box bigboyjoel Home Theater 4 12-19-2007 02:23 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
