Electricity For Shed - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 06:06 PM   #16
kevinp22's Avatar
Rewards Points: 252
the 8 is just needed to reduce voltage drop for the distance from the house to the shed. i would switch back to 12 once it enters the shed -- unless you are buying the 8 in say 200 foot rolls, then no need to waste wire. might be hard to attach 8 to receptacles and switches though
kevinp22 is offline   Reply With Quote
Old 05-27-2012, 06:16 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
A disconnect is required at the out building anyway, so a perfect place to reduce wire size for the interior wiring.
Old 05-27-2012, 06:34 PM   #18
Rewards Points: 174
Thanks, good point, how do I disconnect, assuming just inside wherever the 8/2 wire comes into the shed?
But not a junction box on the outside,correct?
tb582 is offline   Reply With Quote
Old 05-27-2012, 06:37 PM   #19
E2 Electrician
You can do a junction box, but a disconnect is required either inside or outside of the structure at the nearest point of entrance of the conductors.
Old 05-27-2012, 07:40 PM   #20
Licensed electrician
Rewards Points: 1,622
A single or double pole switch could satisfy for a disconnect.
Old 05-27-2012, 09:32 PM   #21
Rewards Points: 174
So just a simple single pole switch that kills the main power coming into the shed? Must it be at the closest point to entry? For instance lid I enter on the side the disconnect must also be on the side?
Old 05-27-2012, 10:45 PM   #22
E2 Electrician
The sad part is, that should be all that is needed, unfortunately, the disconnect has to be suitable for service equipment.
Old 05-28-2012, 12:09 AM   #23
" Euro " electrician
frenchelectrican's Avatar
Not for the shed.
It don't have to use the service equiment rated disconnect switch for this purpose in the shed.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
k_buz (05-28-2012)
Old 05-28-2012, 07:20 AM   #24
E2 Electrician
Originally Posted by frenchelectrican View Post
Not for the shed.
Merci,
Marc
Oh really? better check out 225.36 my friend...
Old 05-28-2012, 07:33 AM   #25
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
You had best read the exception to 225.36 as it specifically applies to an outbuilding in a residual application. A simple snap switch is acceptable.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
frenchelectrican (05-28-2012), stickboy1375 (05-28-2012)
Old 05-28-2012, 08:18 AM   #26
E2 Electrician
haha, awesome, I've read that wrong for a long time, i was reading it as if you just ran a three way out to a building a disconnect wasn't required.
Old 05-28-2012, 08:24 AM   #27
Rewards Points: 1,514
You can provide for the future (more electrical usage out there) by running 3 conductor plus ground cable underground instead of two conductor. You won't be able to use the third conductor yet while you are drawing power fromthe junction box back at the house with the 12-2 feed but later you can extend the 8 gauge wires all the way to the panel for 120 and 240 volt (or two allotments of 120 volts) out at the shed.
Old 05-29-2012, 01:31 PM   #28
Rewards Points: 322
That is a looong ways to pull cable through a conduit. Better start working on a plan!
puttster is offline   Reply With Quote
Running electricity to kitchen island michaelkingdom Electrical 16 03-11-2012 10:26 PM
Cost of installing a separate electricity meter gus wilson Electrical 2 01-04-2012 05:52 AM
What requires electricity? pcampbell HVAC 3 11-05-2011 11:39 AM
How does electricity meter calculate kwh? deerhunter Off Topic 18 09-06-2010 08:26 AM
No electricity in half the room (somewhat complicated) jimbob8690 Electrical 1 07-13-2010 03:23 PM
