Electricity Out In Garage???? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2010, 09:11 PM   #1
electricity out in garage????
Tried using outlet in garage today and had no power. so i tried different outlet same problem. checked gcfi outlets and no light saying they are tripped no power figure breaker tripped. so i go in basement and check breaker and it is not tripped. so i flick breaker off then back on and go back out to check and still no power. this is an old house built in 1928 has 3 lines that run overhead off of back porch to garage for power lines. there was power in garage yesterday and i have not used any outlet except for trying to plug something in today. the garage is not the only thing running off of the breaker a bathroom light and a cpl basement lights run off of same breaker in basement. when the garage had no power the bathroom and basement lights still work no problem so i assume my problem is going to be somewhere from lines running from house to garage or somewhere in garage. any help suggestions greatly appreciated
a68cudas is offline   Reply With Quote
Old 07-02-2010, 09:36 PM   #2
Do you have a meter to measure for power ?
Do you have power at the 1st connection where it enters the garage ?
Old 07-03-2010, 02:19 AM   #3
Union Electrician
goose134's Avatar
Or at the point it leaves the house to the overhead run to the garage.
Just thought of something else. Light on GFI will go out if GFI trips. Try reset button on outlet.
goose134 is offline   Reply With Quote
Old 07-03-2010, 09:26 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Not always. Some GFI's light will come on when tripped...assuming it has power coming in, in the first place.
Kyle
Old 07-03-2010, 11:58 AM   #5
yes i have a meter. havent checked anything yet. about to turn breaker back on and check and see if have power at 1st connection. planned on checking the outlets for loose connections as well
Old 07-03-2010, 12:48 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
are there any joints in the overhead lines that feed the garage? That is a great source of problems.
Old 07-04-2010, 11:34 AM   #7
Master Electrician
pesdfw's Avatar
Pull the GFI out of the wall and check to see if you have power on the "Line" side of the plug between hot (black) and neutral (white). If you do and it won't reset .. bad GFI. If it tries to reset and trips back then it's doing its job and you have a problem somewhere down the circuit. If there is no power you either have a bad breaker or a problem with the wire going from the panel to the GFI.
pesdfw is offline   Reply With Quote
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
electricity from house to garage J MAC Electrical 19 07-05-2009 06:19 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Electricity in the Garage Firsthome2007 Electrical 4 11-19-2008 09:24 AM
