Electricity Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2008, 08:12 AM   #1
Electricity not working
Any ideas about why the electricty in only my guest room isn't working? Could it be a fuse? The breaker box appears fine. Quick/inexpensive fix for it?
southern no more is offline   Reply With Quote
Old 07-07-2008, 08:36 AM   #2
Check your bathroom GFI's.
jerryh3 is offline   Reply With Quote
Old 07-07-2008, 10:44 AM   #3
Rewards Points: 80
The appearance of your breaker panel does not mean that one or more breakers are tripped. Turn breaker all the way off, then back on. You should hear a click when you reset it. Check all of them if you do not know which one feeds the guest room.
If none of the breakers are tripped follow jerry's suggestion and check all GFCI's in the house and make sure none have tripped. Push the trip button first, then push the reset button. You should also hear an audible click when resetting the GFCI.
If it is not any of the GFCI's or a tripped breaker it could be a loose or broken wire or cable. If you feel comfortable working on this project you can try to find the receptacle or cable from the main panel that feeds the guest room. Take a lamp or something to plug into the receptacles. Start checking each one until you find one that does not work. This will give you a place to start. Open receptacle boxes and possibly light fixture boxes and look for a disconnected or loose wire. Trial and error type testing. I would highly suggest you turn off all the power after you have found the starting point.
Old 07-07-2008, 10:47 AM   #4
Thank you for the ideas. I will check into them!
Old 07-08-2008, 08:59 PM   #5
When was your house built? Has their been any updates? Especially in the late 60's and early 70's. Check receptacles for push ins or backstabbing.
rgsgww is offline   Reply With Quote
Old 07-09-2008, 04:36 PM   #6
Oh, how I loathe those "quick-connect" push-ins. The only back-wired I will ever use are the ones where you still need to tighten the screws. I prefer side wired in any case.
FW
fw2007 is offline   Reply With Quote
Old 07-09-2008, 04:39 PM   #7
Don't forget that there could also be a "junction box" with a broken/ pulled out wire.
That may be in your basement, attic, or crawl space.
FW
Old 07-09-2008, 05:40 PM   #8
FW
....I spent an hour fixing my basement from those. Then noticed my heavy load outlets were old and needed new ones...I went with levition commercial grade receptacles. That outlet only has the backwired terminals with the clamp not the easy push ins. But I still use the screws....
Power Washer Chem Feed Not Working robertr4836 Tools 11 11-24-2012 09:43 PM
Inside Fan not working BenH HVAC 20 07-08-2008 07:10 AM
Working with granite... SDeeter19464 Remodeling 5 06-14-2008 06:51 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
