Electricity In My Master Bedroom Goes Out During The Night - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 01:20 PM   #1
electricity in my master bedroom goes out during the night
Why does my electricity go out during a certain part of the night in my master bedroom? It is the only one that trips
rlhill33 is offline   Reply With Quote
Old 07-08-2012, 01:30 PM   #2
Welcome to DIY !!!! Thank you so much for your first post !!! With the vast amount of details you have included I think I may be able to help !!! Do you have a cat ??!! If so, the reason is because the static electricity in their paws are creating an overloaded circuit that your ceiling fan is sensing when on medium. Unless your fan is on high, if that were the case then it is because your clock radio is dialed into 104.8!! Good luck and I hope this helps as I know it did others with the same problem. !!
CopperClad is offline   Reply With Quote
Old 07-08-2012, 07:44 PM   #3
Electrical Contractor
kbsparky's Avatar
What do you have plugged into that circuit? Are there any surge-protected power strips? Is the breaker an Arc-fault type?
Need more info to help you on this ....
-KB
Old 07-09-2012, 04:53 PM   #4
Rewards Points: 150
My bet is mice, and frayed or loose wire. Mice usually stick to a pretty consistent schedule.
We do get a little punchy around here, but in general we are harmless. On the other hand electricity is not harmless. Some basic information like where are you located, age of the house/wiring, list any recent changes to your electrical. Anything else different about the MB, such as do you have a room air conditioner or room fan?
Brainstorm. I like to sing the Sesame Street song while I brainstorm:
One of these things is not like the others,
One of these things just doesn`t belong,
Can you tell which thing is not like the others
By the time I finish my song?
goosebarry is offline   Reply With Quote
The Following User Says Thank You to goosebarry For This Useful Post:
operagost (07-10-2012)
Old 07-09-2012, 05:04 PM   #5
bbo
is it when your SO comes in after finally getting the kids to bed? I know that has sucked the electricity out of our MB more than once.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
Old 07-10-2012, 09:02 AM   #6
Rewards Points: 6,652
Tell your neighbor to quit flipping off the mystery switch in their house/apt/condo.
Pitiful low air flow to master bedroom Rewound98 HVAC 9 11-17-2011 08:04 PM
Location of Heat Registers in Master Bedroom edfromma HVAC 3 12-15-2009 11:08 AM
4th Bedroom Master Addition vidya46 Building & Construction 1 11-15-2009 09:47 AM
Attic Master Bedroom Addition joannek12 Building & Construction 3 10-30-2009 08:01 PM
22x22 addition, basement workshop, mater bedroom above. iMisspell Project Showcase 26 07-21-2009 02:35 PM
