Old 07-03-2009, 05:26 PM   #16
Xtreme DIY'r
electricity from house to garage
Originally Posted by Yoyizit View Post
If it's only a few watts you can run 12v or 24v to the garage and thereby get around some of the more burdensome of NEC rules.
Do garage door openers run on 24v ?
I think buying everything that he wants to use in 12v/24v models will cost more then a sub panel
Old 07-04-2009, 12:49 AM   #17
Average Joe/ex-Navy IC3
gregzoll's Avatar
You do know that you are not in code by running Romex through Conduit all the way.
Old 07-04-2009, 10:13 AM   #18
It was a dark and stormy
Yoyizit's Avatar
1/2 hp at 24v is >15A. You won't save in the cost of wire, that's for sure.
Maybe 15A and below is a good breakpoint for deciding to go low voltage, rather than 120/240v. That, what loads you have, peak watts and average w-h needed.
Old 07-04-2009, 04:45 PM   #19
The NEC doesn't apply to me, as I'm out of jurisdiction. However, the ground temperature is about 20F for 6 months of the year.
Can you imagine, cutting the Romex installing a box, running separate conductors in the conduit, another splice in a box at the other end!
That's just another rule that was dreamed up to cover somebodies back side.
Old 07-05-2009, 07:19 PM   #20
gregzoll's Avatar
It is done that way all the time.
Legal to have subpanel in garage? gante Electrical 36 03-13-2009 04:27 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
detached garage Kapt Electrical 12 01-17-2007 09:37 AM
