Old 07-13-2007, 05:24 PM   #1
Electricity Drain
The electric bill over the last few months has been outrageous like $260-$350 per month between 2 houses and a barn. We use the normal: lights, TV, computer, fridge, ETC... This last month we've both had our AC's off and on as needed w/ nothing else very much differently. This last months bill was just above $110 w/ the AC's. In the barn we use an elec. fence charger, over the high months we had it in use until last month when it hadn't been charging the whole line. My question is... If the box or anywhere along the line was grounding out, would it make the charger use more elec. and ultimately increase the use and bill?
Jeff1374 is offline   Reply With Quote
Old 07-14-2007, 10:53 PM   #2
Master Electrician
JohnJ0906's Avatar
Electricity Drain
Its possible. Do you know what it is supposed to draw, and can you measure the actual draw? (Amps, not volts)
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
