Electricity But No Light - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-19-2014, 08:46 AM   #31
Rewards Points: 24
Originally Posted by Stubbie View Post
Were those 2 wires in the switch box connected to the switch when you took it out?
Reason I'm asking is if you can operate a light bulb (normal brightness) from those wires then you have a incoming hot and incoming neutral wire. If that is the case when you operate the switch it would be a dead short and a fuse should blow or breaker should trip.
Yes, the two wires in the box were connected to a switch. I could try testing again by going through the switch, but I do not have enough bits of wire available for that kind of rig up. I will go look for some wire and try to pass this through the switch and let you know what happens.
Thanks!!
takingtoolong is offline   Reply With Quote
Old 02-19-2014, 08:51 AM   #32
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Thanks!!
If they were connected to the switch wouldn't you have done that already? Something is missing
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-19-2014, 08:59 AM   #33
UAW SKILLED TRADES
Stubbie's Avatar
Thanks!!
I'd rather you do not do that till we figure out what is missing. You actually need to try and find access so you can see how these wires are run. Is there anyone you can call that understands things a bit better that can help you?
Stubbie
Old 02-19-2014, 11:18 PM   #34
dmxtothemax's Avatar
Rewards Points: 5,190
I live in an old house. I cannot see a neutral or ground wire in this box or light fixture. Light does not work. Electronic tester says that there is electricity everywhere, including on the entire lamp. I can touch, without feeling a thing. No other tester, so I cannot tell what the voltage is. Please see pics. Help much appreciated!
How do I fix this?
If your non contact tester is telling you that there is electricity everywhere ? But the light doesn't work, then you have probably lost your neutral.
But tracing K & T wiring can be a royal PITA !
And moving old wiring around can cause problems with
the insulation cracking and falling off !
Probably a bad splice or damaged cable.
I suggest that you read up on K & T wiring,
So you know what your up against !
dmxtothemax is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
