Electrician's Pliers - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2008, 06:49 AM   #1
Rewards Points: 900
Hi;
I have a really simple question.
Do all electrician's side-cutters have grooved jaws?
I'm asking this because, when these are used to twist wires before installing wirenuts, the wires always get scored. Is that OK, or should I be using a smooth jawed plier for this work?
Ultrarunner2017 is offline   Reply With Quote
Old 12-14-2008, 08:15 AM   #2
Whatamess
A lot of guys strip the wire a little long and twist by the ends then cut the scarred ends off.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 12-14-2008, 08:17 AM   #3
Rewards Points: 2,350
Originally Posted by KE2KB View Post
Hi;
I have never seen a smooth jaw pair of lineman's. But the marring is minimal unless you are putting a death grip in the wires. If you hold the wires loosely within the jaws and turn, they should rotate around each other.
Old 12-14-2008, 08:30 AM   #4
joed's Avatar
Rewards Points: 13,720
All the side cutters I have seen do not have any grooves. The entire jaw is a cutter.
If you are talking about linemen's pliers then yes they all have grooved jaws. They would be useless for tighten or loosening any thing with smooth jaws. The tip is most often not grooved for an 1/8 or 3/16 inch.
Old 12-14-2008, 09:33 AM   #5
This must be a regional dialect thing. Where I'm from, lineman's pliers, aka Kleins, are also known as side cutters. What you describe above we call diagonal cutters, or dikes.
Old 12-14-2008, 09:58 AM   #6
Eibwen
All that I have ever seen had grooves on em...
But as a side note, I rarely pre twist wires. Just cut em off square and lay with the stripped ends straight and put on a wire nut.
In fact I just checked a box of nuts and it says no pre twisting needed.
Sammy is offline   Reply With Quote
Old 12-14-2008, 10:13 AM   #7
the Musigician
DangerMouse's Avatar
oh boy.... here we go....
DM
Old 12-14-2008, 10:40 AM   #8
Eibwen
DM I aint kickin no sleepin dawgs!
Old 12-14-2008, 10:59 AM   #9
the Musigician
who said anything about dogs? -=chuckle=-
DM
Old 12-14-2008, 11:04 AM   #10
Eibwen
That looks more like it!
I'm outta here to rake leaves til the game comes on!
Old 12-14-2008, 11:16 AM   #11
Registered User
Termite's Avatar
Wierd! Around here, side cutters are side cutters and linesman pliers are different.
http://en.wikipedia.org/wiki/Lineman's_pliers
Old 12-14-2008, 11:50 AM   #12
Rewards Points: 900
In Rex Cauldwell's "Wiring a House" he refers to the tool as Lineman's or Electrician's cutters, as side cutters, and as Klein. Of course Klein is a brand-name, but I have always referred to them as Lineman's pliers.
Thanks for the advice on (pre)twisting. I will use it next time I have the opportunity to do the twist!
Sometimes though, I cannot get enough "extra" wire stripped to twist by the ends, as in old work where the pervious wirer (I won't call him an electrician, because I suspect that he was not) didn't leave the obligatory 6" of free wire.
I have never seen any really serious scoring of the wires, just that I am a perfectionist.
BTW, my Electrician's pliers are an off-brand that I bought from a mail-order tool and hardware co a very long time ago. They still do the job though.
Old 12-14-2008, 11:58 AM   #13
That's why you call them lineman's pliers, and I call them Kleins
Old 12-14-2008, 12:39 PM   #14
Cool
linemans, side cutters, kleins
all the same thing my freinds, and yes, they do have cross grooves for gripping which will smooth out when you get some real use out of 'em.
if you really were a perfectionest you would only use kleins. lol
by the way, always twist your wires. dont listen to a box. as you all should know, the first thing an electrician does is throw away the instructions.
dumbcluck is offline   Reply With Quote
Old 12-14-2008, 01:58 PM   #15
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
When you buy lineman's pliers the package will say x" side sutting pliers. Diaganal cutting pliers are also called dikes.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
How many electricians.... hvaclover Electrical 5 11-12-2008 11:12 AM
Electricians or know-how only Ultimate_balance Electrical 20 08-17-2008 03:23 PM
Brewers, Electricians, lend me your ear! GFCI problem aekdbbop Electrical 5 06-16-2008 04:14 PM
What are the requirements I must do to get electricians license Kraze Electrical 16 08-28-2007 08:00 PM
Any electricians out there? Panel upgrade! roncon Electrical 1 06-19-2005 12:38 PM
