Old 08-16-2008, 09:43 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Electricians or know-how only
Originally Posted by Ultimate_balance View Post
Do I need a "starter" for compact fluorescent? If not, then what does a starter do?
What does it say in the wiring diagram?
Chances are it does not need a starter. I haven't seen a new ballast need a starter in many years, especially newer electronic ballasts.
What does a starter do, exactly, I have no idea. I never did know.
Old 08-16-2008, 10:11 PM   #17
UAW SKILLED TRADES
Stubbie's Avatar
I'm not certain either, I think they are a time delay mechanism or a closed switch that stays closed a bit to give the filaments at each end of the bulb time to heat up some then the switch/starter contacts open and the bulbs lights up. So I'm guessing they may be like small capacitors and give that needed electrical boost to the filaments that get the electrons flowing through the entrapped gas. Can't remember what they call it ...ion something.
Old 08-16-2008, 11:13 PM   #18
Post
heres the diagram for what i'm using guys:
http://www.fulham.com/images/WDgifs/wire7.gif
the problem with this one is that it actually shows all four pins, while the lampholder reduces this into two receptacles (something like this):
http://www.tlc-direct.co.uk/Images/P...e_3/AALEP6.JPG
this is what the back of my bulb looks like:
http://genet.gelighting.com/LightPro.../r00463v29.jpg
i was wondering "theoretically" how I would get them paired up?
also I have come across one final issue, with the ballasts firmly secured to a non-flammable surface, I want to plant a switch to turn my lights on and off, do I plant it on the positive wire or the negative wire (or does it matter)?
Ultimate_balance is offline   Reply With Quote
Old 08-17-2008, 08:59 AM   #19
Switch the positive ( hot leg) going to the ballast.
This is usually black...
Big Bob is offline   Reply With Quote
Old 08-17-2008, 01:11 PM   #20
Thumbs up
thank you
Old 08-17-2008, 04:23 PM   #21
For good theory and background you might want to visit sites like GE and Phillips... have fun...be careful....and don't burn the place down..
many other ways to do what you are going after.
visit (ASL) American Scientific Lighting on the www. they have their own super smart ballasts... have embraced GU 24 energy star tech, ... have been working with PL lamps for over 25 years....
there is no greater blessing than being happy in your work.
Hot Tub/Spa Installation BigA Electrical 6 03-11-2010 09:12 PM
Brewers, Electricians, lend me your ear! GFCI problem aekdbbop Electrical 5 06-16-2008 05:14 PM
What are the requirements I must do to get electricians license Kraze Electrical 16 08-28-2007 09:00 PM
Any electricians out there? Panel upgrade! roncon Electrical 1 06-19-2005 01:38 PM
any real electricians out there ayoung Electrical 8 04-22-2005 07:42 PM
