Electrician Screwed Up, What Can I Do? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 06:14 AM   #1
Electrician screwed up, what can I do?
I had new cabinets put in and the electrician came and put in under cabinet puck lighting that had transformers in the cabinet. The wiring is all behind the wall except for the wire running to the pucks. My problem is that the electrician wired 4 20 watt lights to a 12531BK 60 watt transformer. You know what happens next. The lights are rather dim especially compared to the 2 on the right side that are connected to another transformer. These are made by Kichler. What can I do? The cabinets are in and I don't want the guy back. All I need to do is switch to a larger transformer right? If so, does Kichler make an 80 watt transformer? If not, who does and what should I do? Thanks.
ingeborgdot is offline   Reply With Quote
Old 08-01-2010, 06:39 AM   #2
biggles's Avatar
the spec info for them should tell you the total lights per TR...another thing to check is did he wire them in series(like christmas lights)or parallel pair of wires off the low voltage side and stack each light on the pair supplying the low voltage.the resistance changes with both wiring either way...to see if they are in series lite the low dimmed one up then disconnect any one if the run goes out your in series....
Old 08-01-2010, 07:23 AM   #3
The transformers are 60 watt transformers. Kichler 12531BK 60 watt transformer. They can handle 60 watts. He wired 4 lights to this one transformer. I am pretty sure they are in parallel just by looking at the wires. Eight wires come out of the wall and then split off into each light.
Old 08-01-2010, 07:37 AM   #4
biggles's Avatar
thats parallel as you descibe it...is i possible the connections are marked to be connected certain ways ?take the dimmed run out and try each lite seperate directly to the TR then add them one at a time see if the previous one starts to dimm...something is pulling on those watts
Old 08-01-2010, 07:39 AM   #5
Master Electrician
Rewards Points: 3,828
Get a larger transformer.
brric is online now   Reply With Quote
Old 08-01-2010, 07:40 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
There is no mystery here. 80 watts of 12v light on a 60 watt transformer.
Simply replace the transformer with the larger one.
Either your guy did not notice this, or he didn't think it would matter. A shame either way.
Old 08-01-2010, 11:18 AM   #7
There are 12V lights using LED technology. If replacing the transformer is not reasonable (hard to believe that this would be the case) you could also try fixtures requiring less power.
oberkc is offline   Reply With Quote
Old 08-01-2010, 11:43 AM   #8
Electrician
Proby's Avatar
Sorry, but I just don't believe it
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-01-2010, 12:23 PM   #9
That's a joke right?
Old 08-01-2010, 03:25 PM   #10
Rewards Points: 372
We have your side, but we need his side before we can know if he should be allowed on the job side.
fireguy is offline   Reply With Quote
Old 08-01-2010, 04:25 PM   #11
Not that he did a bad job it is that he will have to drive 85 miles just to do this little job. The drive mileage will kill me just for that. Why would you need his side anyway? He installed a 60 watt trans for an 80 watt setting? Case closed.
Old 08-01-2010, 05:48 PM   #12
DIY staff
Rewards Points: 7,174
Why not split the wiring to two of the smaller transformers? That should be simple and put the same draw (and the same light level )as the other circuit.
Old 08-01-2010, 07:42 PM   #13
Could you kindly explain. I am not sure what to do. Thanks.
Old 08-01-2010, 07:52 PM   #14
Electrician
Proby's Avatar
What he is saying is if you can't find a larger tranny, you can just get a second one. Then you can use your current for 2 lights and the new one for the other 2 lights.
Old 08-01-2010, 08:05 PM   #15
I understand that. Thanks. I am not sure how that would be done because there are only one wire coming in to the transformer. It has two wires but it only the one wire.
complicating-updating new box for client, electrician messed it up-pics included Kraze Electrical 29 11-18-2012 09:14 PM
Need thoughts on this Electrician bid matjam68 Off Topic 1 03-24-2010 10:24 PM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 07:07 PM
Can I pre-run romex before the electrician shows up? jheavner Electrical 14 10-10-2008 01:00 PM
North Carolina Electrician assistance please buloni Electrical 2 12-03-2005 08:07 PM
