Electrician Funny Business? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 02:15 PM   #1
Trucon01's Avatar
Rewards Points: 510
Electrician funny business?
Hi All,
I just had an electrician give me an estimate to put in a new panel and all new breakers. He told me he couldn't see anywhere it was grounded and I would require 2 rods in the back yard as well as bonding to my water line.
Is this padding a price or is this legit?
Trucon01 is offline   Reply With Quote
Old 01-17-2012, 02:23 PM   #2
Julius793's Avatar
Originally Posted by Trucon01
Hi All,
Legit if there arent any ground rods
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-17-2012, 02:34 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
We are not there, so we can't tell.
Call for another estimite and see what he says.
jbfan is online now   Reply With Quote
Old 01-17-2012, 02:35 PM   #4
Love for Construction
<*(((><'s Avatar
That isn't going to add that much to the cost anyways, or at least it shouldn't. Ground rods can be cheap (depending on material) and not much labor is involved in pounding them into the dirt.
Sounds legit to me, but I would verify by looking at the panel when he has it open and see if there is a large bare copper wire that exits the panel.
-luke-
<*(((>< is offline   Reply With Quote
Old 01-17-2012, 02:37 PM   #5
Licensed electrician
Rewards Points: 1,486
The new panel needs to meet todays code requirements. Before you could ground to an accessible part of the water line, now it must go to within 5' of where the pipe eneters the building.
Even if there was one rod another might need to be added.
I am not there but what was said sounds kosher.
Code05 (01-19-2012)
Old 01-17-2012, 07:14 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Don't trust him. All electricians are crooks!
The Following 8 Users Say Thank You to Speedy Petey For This Useful Post:
AtlanticWBConst. (01-18-2012), a_lost_shadow (01-17-2012), bbo (01-17-2012), Code05 (01-19-2012), HouseHelper (01-18-2012), jproffer (01-17-2012), oh'mike (01-18-2012), plummen (01-17-2012)
Old 01-17-2012, 07:21 PM   #7
bbo
I'm shocked ... just shocked ...
( I do have a day job too )
bbo is offline   Reply With Quote
Old 01-17-2012, 07:54 PM   #8
Master Electrician
Rewards Points: 3,820
Originally Posted by Trucon01 View Post
Hi All,
So, what is his/her price?
brric is offline   Reply With Quote
Old 01-17-2012, 08:00 PM   #9
MarginallyQualified
Rewards Points: 2,464
He told me he couldn't see anywhere it was grounded and I would require 2 rods...
Can you see the rods?
Can you see where any heavy gauge solid copper grounding wire exists?
(from the panel and usually downward)
Old 01-18-2012, 12:31 AM   #10
Julius793's Avatar
All??? I know you are but how about me?
Old 01-18-2012, 06:16 AM   #11
At least one rod is required everywhere. Some areas have poor soil conditions, and require two. And connection to the metal water pipe is also required.
Old 01-18-2012, 04:28 PM   #12
Hardcore DIY'er
Sounds very legit, I did my own cold water bond but left the ground rods to my electrician as he already had a jackhammer to run them in.
EvilNCarnate is offline   Reply With Quote
Old 01-18-2012, 04:32 PM   #13
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
The grounding rods are a legit requirement - if you do not have them = and yes, there are 2 rods required min. 6' apart.
- Build Well -
Old 01-18-2012, 05:53 PM   #14
Rewards Points: 240
You'll get a charge out of him... nyuk nyuk
fa_f3_20 is offline   Reply With Quote
Old 01-19-2012, 06:07 AM   #15
Code05's Avatar
Rewards Points: 1,104
Rods are not required per se, but are a quick and cheap solution.
Yes, if it qualifies as an electrode
Supplementing the water pipe electrode with rods is one method, but there are others.
Code05 is offline   Reply With Quote
Licensed Electrician or Not? taras1 Electrical 10 04-29-2011 06:23 PM
Do I Need to Call in a Electrician to Check This Work? taras1 Electrical 6 12-13-2010 05:07 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 08:39 AM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 07:07 PM
