Electricial Insulation Safety - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2009, 09:38 AM   #1
Rewards Points: 672
I am installing a simple candy dish light fixture in my ceiling "tying" off of the wiring of another light. Question, after installing the circular ceiling box in the ceiling, I can feel air coming through the box openings from above(no access to above). Can I insert fiberglass insulation into the box to stop the airflow? Or is this not safe around the wire connections? Suggestions? Thanks!
kennykenny is offline   Reply With Quote
Old 07-06-2009, 09:45 AM   #2
Rewards Points: 502
No, not in the box. You can put insulation above the box and around the outside of it only.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 07-06-2009, 10:14 AM   #3
Rewards Points: 204
You could use of that foam stuff. It works great, but it very messy and does not clean up with soap and water. Just push some insulation in and around the opening and install the fixture.
Old 07-06-2009, 10:43 AM   #4
Journeyman Wireman
No way would I put any type of insulation in the box. Good luck with the foam if you don't hook it up right or there is a problem later. A lot of fixtures have a layer of fiberglass insulation that sits between the fixture and the sheetrock. The heat from the fixture should offset the cold, too.
jbberns is offline   Reply With Quote
Old 07-06-2009, 01:32 PM   #5
Rewards Points: 672
I thought about the foam but agree that it is very messy and can be a pain. With the fiberglass insulation, can I just wrap it around the circular lighting box and secure it with the silver tape to the box? Is that safe?
Old 07-06-2009, 01:40 PM   #6
Journeyman Wireman
That sounds fine to me
Old 07-07-2009, 10:58 AM   #7
Rewards Points: 204
Not in the box, around the box. You are not reading before you post.
Old 07-07-2009, 12:46 PM   #8
Journeyman Wireman
Oh, sorry. I thought "IN and around the opening" meant in the box.
Old 07-07-2009, 01:05 PM   #9
installing Fiberglass Insulation INSIDE? the box!
J.V. is admonishing a poster for not reading before posting... But the starter of this thread, KennyKenny DOES ask if he could stick Fiberglass Insulation INSIDE the box. Most posters answered --correctly-- that inside the box is a no-no. Around the box is OK. The amazing thing is that a [basic] light fixture is made with Fiberglas (Correct spelling of Trademark) and silver foil sheet (or sheath) inside!Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
2x4 Exterior Wall Insulation stubits Building & Construction 4 03-19-2009 07:03 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
