Electrical Wiring Theater Setup - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 06:24 AM   #1
Rewards Points: 156
Electrical wiring theater setup
I have a question on how many circuits to run and what size wire/amp breaker to use. Here is what I am planning on doing:
Circuit #1
Optoma HD20 Projector and Remote Screen
6 5" can lights rated for 75 watt max ( I use CFL's though)
3 Billet lights 50 watt max each
50 feet of LED rope light 1 watt per foot.
Circuit#2
All wall recepticals (6.1 surround sound with subwoofer)
Possibly space heater of some sort and maybe a lamp or something
There will also be approximately 6-8 additional outlets that will probably never have anything plugged in.
I'd prefer to run all this on 15 amp circuits since 14/2 is much easier to work with.
ryan5068 is offline   Reply With Quote
Old 08-12-2011, 07:55 AM   #2
Rewards Points: 6,652
Keep the lighting isolated from the electronics. That means having them on their own circuit. Currently how large is the service to the house now, and how old is it?
Old 08-13-2011, 03:17 AM   #3
Rewards Points: 156
200 amp service and the house was built in 2006. Well that really sucks about keeping them seperate as I am running out of breaker space. Should I do the projector and all the electronics on one and all the lights on the other then. Would a 20 amp be enough to hold the projector and audio equiptment. I am not looking to buy a really high powered surround system but something decent. Thanks
Old 08-13-2011, 06:24 AM   #4
Rewards Points: 1,192
I agree with gregzoll. I would run 20 amp circuits for receptacles,15 for lighting,dedicated circuit for projector.
bobelectric is offline   Reply With Quote
Old 08-13-2011, 08:17 AM   #5
It is about keeping the noise from the high use electrics like hvac, dryer, electric stove if you have, etc from the electronics. Put in a Sub-panel for the home theater. Tripp Lite is one of the best companies out there for isolation transformers, and electronic racks. Especially if you are spending thousands in projector, and a/v equipment. If you plan on staying there for over ten years, I would spend the money. You can get away with a rack mount type surge suppressor/isolation transformers.
http://www.customavrack.com/Products...espikeemi.aspx
http://www.smarthome.com/4413/Isobar...pressor/p.aspx
http://www.tripplite.com/en/index.cfm
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 12:16 PM
New home theater setup Mills314 Home Theater 9 08-02-2011 11:55 PM
Electrical Code for running wiring for pots lights hellothere123 Electrical 5 07-14-2011 12:40 PM
House electrical wiring issue. gnidaerd General DIY Discussions 5 06-07-2009 03:42 AM
home theater setup cannouu Electrical 5 04-09-2008 07:01 AM
