Electrical Wiring Running Parellel And Through Ductwork? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2007, 09:42 AM   #1
Electrical wiring running parellel and through ductwork?
I keep finding interesting things in this rental home. The basement has an open ceiling in most areas. The "duct" leading to the external compressor is sheet metal nailed over a pair of floor joists to turn them into a duct.
However, it appears than when it was installed, the installer didn't worry about the electrical wiring that was already going through those joists. There are about eight wires which go through those joists, parallel to them, and most of them are through holes that aren't sealed well.
Thoughts?
Beren is offline   Reply With Quote
Old 06-01-2007, 05:08 PM   #2
Master Electrician
JohnJ0906's Avatar
Are the wires parallel or perpendicular? If the wires are going ACROSS the airflow, it's OK.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
