Electrical Wiring Mess Up - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 09:47 AM   #1
Electrical wiring mess up
I need Help, I had a contractor come to my house and bulid an addition onto my house.
Well he took 3 light and ran it off the kitchen power source, so now what happens is when i turn off the kitchen light it turns off the other 2 lights in the new part of the house.
I want to remove those 2 other light off the kitchen switch how do I do that, HELP!!!!!!!!!!!!!!!!!!!
Anna Burgos725
AnnaBurgos725 is offline   Reply With Quote
Old 08-22-2012, 09:57 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,258
Call the contractor back to fix it. was this work dome with building and electrical permits?
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
jbfan (08-22-2012), Speedy Petey (08-22-2012)
Old 08-22-2012, 02:42 PM   #3
joed's Avatar
Rewards Points: 13,718
You need to find a source of unswitched power for your addition. That source could be in the existing fixture or you could need to run the cable to whole new location. Only someone on site can tell that.
Old 08-22-2012, 08:00 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,608
Anna Burgos725
Here's what we need to know ?
1 - Can it be changed by you ?
2 - Where there any permits involved ?
3 - Did the wires for the new lights come from
the kitchen light fitting or the switch ?
4 - Is there a neutral at the switch ?
If you dont know,
post pics of the wiring at kitchen switch and fitting.
I suspect the wiring comes from the light fitting,
this is where the neutral is and it would explain why
the lights go off.
But you need to come from the switch, to get a permanent hot.
But you also need a neutral, which might not be at the switch,
if they are using a switch loop !
So we need to find out if there is a neutral at the switch !
Pis's of switch wiring would help heaps !
dmxtothemax is offline   Reply With Quote
Old 08-22-2012, 10:29 PM   #5
dogris's Avatar
Some contractor! Well at least the light bulbs didn't fill with water!
dogris is offline   Reply With Quote
Old 08-23-2012, 07:08 AM   #6
wiring mess up
The contractor won't come back, why I don't no..and yes there were permits involved.
Now, yes I can change it myself
yes, there were permits involved
it came from the kitchen light fitting
no neutral at the switch
the wiring came from the lights
which means I will have to run some new wire and connect to a hold new switch, in order to take it off the kitchen switch, right? I want those lights to run off there own switch and not be controled off the kitchen switch
Anna
Old 08-23-2012, 07:37 AM   #7
joed's Avatar
You need to tell us about the wires in the fixture where he took power from. It could be very simple to just switch two wires.
Old 08-23-2012, 08:00 AM   #8
Master Electrician
Errrr if there were permits it should have been inspected. File a complaint.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-23-2012, 08:05 AM   #9
wire mess up
he took the power from the existing light that was in the kitchen. he took 2 lights from the new area bulit on, and connected the 2 new light together, then took those 2 new light and ran the wire into my already exisiting kitchen light and wired it all together. so now when you turn on the kitchen light the other 2 new lights come on with the kitchen light and go off when i turn the kitchen light on, get it...........
i don't want 3 light connected to one switch get it, the dummpy contractor was suppose to give each light there on switch, but instead he added it all onto one switch witch was the kitchen switch. so now i'm trying to re-route this so that all 3 lights will have there own switch, got it..lol crazy right
Anna
Old 08-23-2012, 12:41 PM   #10
joed's Avatar
Inspector will not verify functionality. He will only verify code certified installation.
If you can open the fixture in the kitchen where he made the connections and tell us all the wire connections then it might be as simple a swapping two wires. Or take a picture show us all the wires in the fixture.
Old 08-23-2012, 01:01 PM   #11
Master Electrician
What I was getting at was that of it was inspected and permitted then it should have been a licensed electrical contractor. There must be a governing body in the states where you can file a complaint.
Old 08-23-2012, 06:07 PM   #12
Anna
If the power goes to the fitting first, and there is a switch lop from there
then it looks good!
The hot wire for the two new lights (should be black) ,
is connectted to the wrong side of the switch loop.
Use a checker,
check both wires that are the switch loop,
one should be permanent hot,
the other should be on or off depending on the position of the switch,
this wire is where the existing hot probably comes from,
but this is wrong !
it should go to the other side of the switch loop, which is permanent hot.
Be careful, check each and every step before you proceed.
If in doubt, ! don't do it , till you are 100% sure.
A good electricain would sort this one out real quick.
Old 08-24-2012, 07:27 AM   #13
wiring mess up
Thanks to everyone, who answered my question and gave me pointers, I fixed it, i'm gonna be the next HGTV fixer winner...
I ran another line and put in another switch to make those lights work on it's own source. I used the hot from the one of the plugs and it work.
Hooray!!!!!!!!!!!!!!!!!!!!!
thanks everybody
Anna
How do you work on electrical wiring stuffs when there is insulation in the attic? htabbas Electrical 19 01-08-2012 01:03 AM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Vintage Refrigerator: help with electrical wiring shocked Electrical 3 12-03-2011 07:27 PM
Electrical wiring! Kyle1971 Electrical 7 04-25-2011 04:53 PM
exposed electrical wiring in basement ceiling zemdegs Electrical 4 01-03-2011 05:08 PM
