Electrical Wiring Home ? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 07:58 PM   #1
electrical wiring home ?
just purchased a small chandelier for the living room
and the instructions say connect electriacl box black wire to the black fixture wire and the electrical box white wire to the white fixture wire
also there was a green wire which im sure is the ground so screwed that with existing ground on elicrical box......
problem there was no white wire on the chandelier fixture as in the instructions,,but 2 black wire and a green wire....so
i hooked up the black with black and the other black with white and geen to ground....
light works but when this happens the plugs for my computer in anther room go off and the breaker on the fuse box turns to off....
so what to do
anyone
thanks
dcjcdc is offline   Reply With Quote
Old 07-25-2010, 09:01 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
dc, Welcome to the forum
Was there an existing ceiling lamp fixture connected to a wall switch, before you installed the new chandelier?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-25-2010, 09:03 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Easiest way to know which black wire is which, do a continuity test from one of the black wires to the outer part of the light socket. If it passes, then that's the neutral, if not, then the other one is neutral. You can use a multi meter with continuity test feature, or use a battery flashlight bulb.
Old 07-25-2010, 09:21 PM   #4
Electrician
Proby's Avatar
Are you SURE that those are your only wires?
I have a feeling that the chandelier has (2) black wires and (2) white wires. You found the blacks, but the whites are tangled up below.
It's common for fixtures to have multiple sets of wires coming up out of them, they need to be spliced together in the box.
Proby is offline   Reply With Quote
Old 07-25-2010, 10:02 PM   #5
yes there was an exsisting light there
which had a black and a white wire coming out
thanks
Old 07-25-2010, 10:04 PM   #6
response
thanks for the responses
was thinking tomorrow to maybe just switch the black wires and see what happens
Old 07-26-2010, 01:42 PM   #7
response
well took down the chandelier.....there is no white wire hidden
the one black wire that splits in two
one black wire has no writing on it while the other
black wire has this written on it
(ul e167861 spt-2 18awgx2c vw-1 105 c kenic csa ll79248 )
has a 4 eletronic transformers
Old 07-26-2010, 01:56 PM   #8
pic of bottom of chandelier
Old 07-26-2010, 02:27 PM   #9
Electrician
Proby's Avatar
What is in the center of the chandelier? You see where the two wires with the wirenuts on them are going? What is underneath that?
Second, do you see that bundle of white and the bundle of black wires spliced together? Give those a pull, make sure that there isn't a black and white pigtail mixed into those wires.
Old 07-26-2010, 02:53 PM   #10
Tool Geek
PaliBob's Avatar
dc, You have a Fluorescent Light fixture.
A chandelier is a branched, decorative lighting fixture that holds a number of bulbs or candles and is suspended from a ceiling.
Your pic shows the ballast wiring that is required to operate the fluorescent bulb..
Your ballast wiring does not care about black/white polarity.
Connect one of the fixture orange capped wires to the white wire in the ceiling box that was connected to your original ceiling fixture.
Connect the other fixture orange capped wire to the black ceiling box wire that was
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-26-2010, 02:58 PM   #11
Electrician
Proby's Avatar
PaliBob, he connected it that way already, as he explained in his first post, but the breaker is tripping.
Old 07-26-2010, 03:00 PM   #12
response
yes it is florestant
i put those orange caps on...
yes i did at first put the black with black and the black with existing white that is on the ceiling and it works but the power on went out in another room as it tripped the breaker...
Old 07-26-2010, 03:56 PM   #13
palibob
do you think it wil make any difference if i go black and black and try the other black to the white wire on the ceiling box..
thanks
Old 07-26-2010, 04:38 PM   #14
Tool Geek
PaliBob's Avatar
dc, Thanks for posting the chandelier Pic.
Very cool, can you post a Link
You somehow now have a short between the black (Hot) and the White (neutral) or a ground.
I would completely remove the new chandelier, find and correct the short so that the fuse does not blow, then reinstall the new chandelier.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-26-2010, 04:55 PM   #15
pali bob
just remove dthe chandilier
but the old fixture on...and everything worked,,did not trip any fuse breakers....
maybe this chandiler is too powerful fur the breaker
House electrical wiring issue. gnidaerd General DIY Discussions 5 06-07-2009 02:42 AM
Adding additional wiring to new block home sailorman Electrical 6 05-28-2009 01:27 PM
Polarized plug light fixture- Hardwire to home electrical? timdavis3824 Electrical 3 07-09-2007 12:34 PM
Electrical wiring running parellel and through ductwork? Beren HVAC 4 06-02-2007 12:32 AM
Electrical wiring running parellel and through ductwork? Beren Electrical 1 06-01-2007 04:08 PM
