Electrical/wiring Concerns - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 03:03 PM   #16
scuba dave... you mean #4 or use #3? You repeated saying #4 so I just want to make sure if it's #4 or #3. Thank you!
also realized i typed scuba steve before... interesting how the mind relates with error.
inlovewithohio is offline   Reply With Quote
Old 09-29-2010, 04:41 PM   #17
Sorry....I meant #3 for 100a for a sub
Old 09-30-2010, 11:22 AM   #18
Rewards Points: 160
Originally Posted by Scuba_Dave View Post
I thought #4 THWN is only good for 85a ?
Originally Posted by frenchelectrican View Post
J.V.
I just don't want this get missunderstood but I know you mention #4 THHN/THWN conductor size.
Normally I will recommed to use the #3 THHN/THWN conductor that is good for 100 amp breaker.
That is for feeder useage not the Service entrance useage that what it will affect it.
Merci.
Marc
Sorry guys. I should have said #3 Cu.
Old 12-01-2010, 11:14 AM   #19
became to busy with person/work life. had an electrician through the family network come over and run the line while i was out. he ran two #6 as hot, one #8 as neutral and a #10 as ground.
He said all i have to do is buy the 60 amp double pole breaker and a new box for the garage and i'll be set.
now the question... what size box? i need at least 8 spaces.
thanks again for all the help
Old 12-01-2010, 12:04 PM   #20
Mad Scientist
You can use any size box, as long as it has a main breaker. I usually just use a 20-space 100A main breaker panel. The rating of the main breaker on the sub-panel doesn't matter, as long as it's at least as high as the breaker feeding it. It's just used as a disconnect, not for protection. The subpanel must also have separate bars for the neutrals and grounds. Most of the time, the separate ground bar must be purchased as an add-on.
I'm not sure how I feel about that #8 for a neutral, though. I thought code only allows for an undersized neutral in some very specific cases. I'll defer to the pros here for that.
McSteve is offline   Reply With Quote
Old 12-01-2010, 09:33 PM   #21
" Euro " electrician
frenchelectrican's Avatar
That part what the electrician did use one size smaller for netural IMO that do not really fly in most area I never do that route even it is classifed as feeder still the wisest move is use full size netural and be done with it.
{ Less issue with voltage drop. }
Merci.
Marc
New Sod - concerns blam Landscaping & Lawn Care 6 06-23-2010 10:55 AM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
backfill concerns morta General DIY Discussions 5 11-22-2008 07:17 PM
Concerns On Hardiplank Install ptra Building & Construction 2 04-23-2008 05:51 PM
Survey Results - Cavity Wall Insulation - Health Concerns mchu6am4 Building & Construction 5 03-14-2007 02:50 PM
