Old 03-23-2012, 02:01 PM   #1
electrical wiring in basement
Hello,
I'm looking to run a few circuits in my home and the electric panel is on the bottom floor of a slab home. I'm thinking of running wire along top edge of cinder blocks (along sill plate) on top edge of foundation. Is this safe, or should I cut ceiling down and wire thru joists? Any suggestions/help would be great.
Marc Frederick is offline   Reply With Quote
Old 03-23-2012, 02:20 PM   #2
MarginallyQualified
Originally Posted by Marc Frederick View Post
I'm looking to run a few circuits in my (SLAB) home...
What is ABOVE the living space?
Ideally... you'll have (or make) access through the floor joists to where it's convenient to then go up to the room you want the power or to a convenient place to go up to the "attic"... and from there over to where you can take the wires down to where you want the power.
Going outside and around the house is sometimes needed,
I've done it myself twice... but only as a last resort (or real short run).
hth
Old 03-23-2012, 02:32 PM   #3
Thanks for the reply.
I don't need power above the room. I wanted to add some power to the room and to the adjoining room on the same floor. Running the power right along the top of the cinderblock foundation is the straightest shot. I just don't know if it is code.
Old 03-23-2012, 03:04 PM   #4
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
IMHO going outside the house and back inside is a complete hack job and should never be accepted. Even if the cable is outdoor rated which it would have to be.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-23-2012, 03:54 PM   #5
joed's Avatar
Is it a slab or a basement? It can't be both.
The cable must be protected from damage.
Do not PM with questions that can be asked in a forum. I will not respond.
Tags
electric circuit, electrical wiring, wiring in basement, wiring problem
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
wiring 3 way switch for basement juliotjs Electrical 2 09-19-2009 06:24 AM
wiring basement lighting 8roty Electrical 21 07-26-2009 11:33 PM
Electrical problem, bad wiring? mumblemouth Electrical 10 08-09-2008 12:52 PM
