Electrical Wiring Advice - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2009, 09:41 AM   #1
Hi,
If this is not the correct place to post please let me know - thanks.
I have had a new motherboard fitted ant home and a wire run to the bathroom for the shower and pull switch, and spotted some bare wires. I think this is especially bad as it sits beneath the insulation?
Can anyone give me constructive feedback? Is this likely to cause a fire?
The first picture is taken from inside the loft, the second from the bathroom below.
As you can see the yellow and green wire has copper wire exposed.
grid is offline   Reply With Quote
Old 07-05-2009, 09:59 AM   #2
300zx's Avatar
Wires should be in a box you could get a round cut-in box.Also is the pull chain in the shower?
300zx is offline   Reply With Quote
Old 07-05-2009, 09:59 AM   #3
Knucklez's Avatar
Rewards Points: 932
this is what i would consider doing..
if rewiring is not practical.. turn off the power at the breaker, disconnect the wire from the switch box and push or pull the wire so that the part where the insulation is missing from the wire is fully exposed (i.e. not half of it in the drywall). then slip a piece of heat-shrink over the wire, and another piece of heat-shrink over the other wire and slide them down so they cover the insulation area with overlap of 1" on each side. heat it up and you're done. HD sells this product.
i'll let others tell you if this solution is to code or not ?
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 07-05-2009, 10:00 AM   #4
Rewards Points: 2,350
I can tell by your language that you must either be Australian or English, so not many here will know about rules and methods there, but one thing is clear: the wiring is NOT supposed to be exposed like that. It needs to go all the way into the switch and terminate in such a way as to be secured. Whoever installed this did a poor job. You should call them back and give them an ear full and demand they do it properly.
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Electrical SubMeter Wiring Help - Please. Jasondt2001 Electrical 50 01-07-2009 02:35 PM
How can I tell if there is electrical wiring beneath kitchen tiles? Mr T Electrical 8 01-04-2009 04:40 PM
Moving oven and cooktop to island; need electrical advice worldtravelerall7 Electrical 3 06-17-2007 03:32 PM
Electrical wiring asuka Electrical 1 02-22-2005 10:44 PM
