Electrical Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 10:55 AM   #1
electrical wiring
How do I change a 3 way switch wiring and install a 3 way switch with an outlet included.
Beanstalk is offline   Reply With Quote
Old 12-06-2012, 11:06 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Existing switch, new install
Way to little info provided.
jbfan is online now   Reply With Quote
Old 12-06-2012, 11:23 AM   #3
Rewards Points: 2,516
Is the outlet always HOT or do you want the outlet controlled by the switches.
In the diagram below, the outlet is always hot. As long as you have a neutral at the switch location you can add the outlet. As long as the current 3-way switch setup is functioning properly, just replace the wires from old switch to the new switch.
No ground wires show for ease of drawing.
hammerlane is offline   Reply With Quote
Old 12-06-2012, 11:25 AM   #4
TTW
TTW's Avatar
Like JBfan said, need more info!
new switch? replacing existing switch? replacing existing 3 way switch? replacing existing standard switch? new receptacle? want to control existing receptacle? want to control both sockets or just 1?
You get the idea...
TTW is offline   Reply With Quote
Old 12-06-2012, 12:55 PM   #5
joed's Avatar
Rewards Points: 13,740
Not enough info but I can tell you if the switch only has three wires and a ground in the box you can NOT do it.
The Following User Says Thank You to joed For This Useful Post:
Speedy Petey (12-07-2012)
Old 12-06-2012, 12:59 PM   #6
TTW
TTW's Avatar
Nice drawing!
Do you do those yourself? If so, what do you use?
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
Old 12-06-2012, 02:06 PM   #7
Oso954's Avatar
Rewards Points: 1,664
More info is needed from the OP.
When I read it, i thought he is trying to replace an existing 3 way with one of these.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 12-07-2012, 08:11 AM   #8
Originally Posted by TTW View Post
Nice drawing!
I use microsoft paint program, Turn the canvas light gray and get to drawing using the line tool. For the devices I just save piictures and paste them in.
The Following User Says Thank You to hammerlane For This Useful Post:
TTW (12-07-2012)
Old 12-07-2012, 08:13 AM   #9
TTW
TTW's Avatar
Cool, thanks, you do a good job.
Old 12-07-2012, 08:17 AM   #10
heres my "best" work.. poster wanted to have like 11 can lites(5 on one side and 6 on the other side) in his basement controlled from 3 locations and noted that a center beam ran along the length of the basement.
Old 12-07-2012, 09:07 AM   #11
Rewards Points: 150
More about Paint...
If you hold down the Shift key while you drag with the Line Tool, the line will be constrained to be horizontal, vertical, or at 45 degrees.
If you hold down the Shift key while you drag either of the Rectangle tools, the rectangle will be a square.
If you hold down the Shift key while you drag the Oval tool, the oval will be a circle.
Left click on a color in the Palette to select a color. If the object has a border color and a fill color, left click selects the border color and right click to select the fill color.
Dave632 is offline   Reply With Quote
The Following 2 Users Say Thank You to Dave632 For This Useful Post:
hammerlane (12-07-2012), TTW (12-07-2012)
Old 12-07-2012, 12:25 PM   #12
Originally Posted by Dave632 View Post
More about Paint...
good tips...did not know that about the shift key
How do you work on electrical wiring stuffs when there is insulation in the attic? htabbas Electrical 19 01-08-2012 01:03 AM
Electrical wiring covered by ductwork ok? Ginny28 HVAC 5 01-04-2012 08:20 PM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Electrical wiring! Kyle1971 Electrical 7 04-25-2011 04:53 PM
How can I tell if there is electrical wiring beneath kitchen tiles? Mr T Electrical 8 01-04-2009 04:40 PM
