Old 10-02-2012, 05:57 PM   #1
Question
Electrical wiring.
Can you connect three electrical set writings in one outlet?
Nicoleallenn is offline   Reply With Quote
Old 10-02-2012, 06:09 PM   #2
Licensed electrician
Electrical wiring.
If the box is big enough you can.
Pigtailing the wires is the way to accomplish this. You cannot have more than one wire under the screw heads.
Tags
nathan
How do you work on electrical wiring stuffs when there is insulation in the attic? htabbas Electrical 19 01-08-2012 02:03 AM
Electrical wiring covered by ductwork ok? Ginny28 HVAC 5 01-04-2012 09:20 PM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 11:04 PM
Electrical wiring! Kyle1971 Electrical 7 04-25-2011 05:53 PM
How can I tell if there is electrical wiring beneath kitchen tiles? Mr T Electrical 8 01-04-2009 05:40 PM
